turning airinntake on LS7?
Old 05-09-2013, 07:56 AM
stigaa
stigaa's Avatar
Default turning airinntake on LS7?
Hi i just wonder if someone could help me out with a strange case
a friend of mine is mounting a LS7 engine into a De Tomaso Pantera, but since the space is very limited and the airinntake will originally be inside the coupe of the vehicle, his question is if it is possible to turn around the airinntake 180 degress on the engine so he could have the airfilter and the mas airflow housing facing backwords into the engine compartment would really apreciate if someone have any experience with this issue
Old 05-09-2013, 10:40 AM
haljensen
Support Corvetteforum!
haljensen's Avatar
It's not ram air so the intake can face any direction you want.
This 'friend" is doing an engine swap into a Pantera?
Old 05-09-2013, 12:03 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
I believe he is asking if the intake manifold, not the air breather, can be rotated 180* so that the air breather and MAF is at the rear of the engine.
I've never heard of anyone doing it, but since the heads are the same, just reversed, it would seem that flipping the intake manifold around, the ports and the mounting bolts would still line up. Might have a clearance problem with the oil pressure sensor, but that should be a minor problem.
Old 05-10-2013, 03:30 AM
stigaa
stigaa's Avatar
Default sorry for not beeing cleare
Hi sorry for not beeing clear yes it is correct it is intake manifoild i mean, the oil pressure sensore isnt a problem since it can be moved down to the oilfilter housing
Old 05-10-2013, 06:29 AM
glenB
glenB's Avatar
St. Jude Donor '08-'09 & '12, '14
Yes, it can be turned 180* and Katech has a kit for the oil sender that gets it out of the way.
Old 05-10-2013, 07:50 AM
truckplay
truckplay's Avatar
that seems like an interesting project
I would love to see pictures of the build. didn't that car come with a 351 ford engine ?
Old 05-10-2013, 08:12 AM
timd38
timd38's Avatar
Gearz on Speed did it on a kit car they built. It worked fine.
Schwartz Performance in a Northern suburb of Chicago then put twin turbos on it.
Here is a link. http://staceydavid.com/projects/sl-c
Old 05-15-2013, 12:24 PM
stigaa
stigaa's Avatar
hey yes it is a 351 cleavland i sure would love to se his modification my self when finnished
Old 05-15-2013, 12:25 PM
stigaa
stigaa's Avatar
Default Thanks
Thanks alot for all advices on this tread
Old 05-15-2013, 01:50 PM
Zip Corvettes
Platinum Supporting Vendor
Zip Corvettes's Avatar
Yes, that is the way it mounts when you use the LS engine in the factory 5 kit car.
Old 05-15-2013, 02:57 PM
cclive
cclive's Avatar
Wow...what a great project. The Pantera was a great car and the LS7 would be a really big upgrade to the 351 Cleveland.
To turning airinntake on LS7?
Quick Reply: turning airinntake on LS7?
