Every Tech should have this LS Timing cover Alignment Tool!
Old 08-25-2016, 11:32 PM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Originally Posted by ez2spd
Remove the hood, much easier to Access!
On a side note. I wish I used this! 2k miles and I have a very small leak after cam swap! Sooooo back apart it comes and will now have it in my tool box!
Hi ez2spd:
Sorry to hear that.yeah the tool will lineup the cover perfectly to help prevent leaks like that.
Thanks,
Norma
SacCityCorvette
Old 06-29-2017, 07:12 AM
conradb
conradb's Avatar
Just found your tool and the upgraded oil barbell. I purchased them in prep for my LS6 refresh and dry sump install. Thanks!
SacCityCorvette (07-12-2017)
Old 07-12-2017, 01:22 AM
SacCityCorvette
Supporting Vendor
Hi Conradb:
We are sure you'll be happy with purchase,Thank you for your business!
Norma
SacCityCorvette
Old 03-17-2018, 11:47 AM
PAmotorman
PAmotorman's Avatar
the BBC 1965 396 did not have alignment pins for the timing gear cover so i made this alignment fixture back then
Old 03-20-2018, 01:14 AM
SacCityCorvette
Supporting Vendor
Good job PAmotorman!
Old 09-27-2019, 03:41 AM
SacCityCorvette
Supporting Vendor
Hi all!
If you're doing an engine build or cam swap, these tools will help prevent premature seal wear and leaks.
https://www.saccitycorvette.com/AlignItTools.html
Also, while doing that build or rear main seal, its a good time to install our Billet Barbell to help keep unfiltered oil out of your bearings and lifters.
Check out our Billet Oil System Improvement Parts.
https://www.saccitycorvette.com/OilS...provement.html
Thank you,
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 10-12-2019, 06:18 AM
Vette Threat
Vette Threat's Avatar
Thanks bro!!
When I was at GM I would just use the J-Tool but always wanted one of my own. I'll be doing a cam over the winter and this tool is a MUST!!!!
Believe it or not, I've seen guys do front covers without the tool.
I'll be in touch.......
JT
Old 10-14-2019, 01:18 AM
SacCityCorvette
Supporting Vendor
Originally Posted by Vette Threat
Thanks bro!!
JT
Thank you and we have them waiting for you when you're ready!
Christian
Old 04-21-2022, 09:50 PM
SacCityCorvette
Supporting Vendor
Hi Everyone,
Just a reminder that we have the AlignIt Tools and Billet oil system improvement parts in stock if you're
working on your engine and need them. Same business day shipping.
Thank you,
Christian
Quick Reply: Every Tech should have this LS Timing cover Alignment Tool!
