Every Tech should have this LS Timing cover Alignment Tool!
Supporting Vendor
Sorry to hear that.yeah the tool will lineup the cover perfectly to help prevent leaks like that.
Thanks,
Norma
SacCityCorvette
SacCityCorvette (07-12-2017)
Supporting Vendor
Supporting Vendor
Good job PAmotorman!
Supporting Vendor
Hi all!
If you're doing an engine build or cam swap, these tools will help prevent premature seal wear and leaks.
https://www.saccitycorvette.com/AlignItTools.html
Also, while doing that build or rear main seal, its a good time to install our Billet Barbell to help keep unfiltered oil out of your bearings and lifters.
Check out our Billet Oil System Improvement Parts.
https://www.saccitycorvette.com/OilS...provement.html
Thank you,
Christian
Thank you,
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Thanks bro!!
When I was at GM I would just use the J-Tool but always wanted one of my own. I'll be doing a cam over the winter and this tool is a MUST!!!!
Believe it or not, I've seen guys do front covers without the tool.
I'll be in touch.......
JT
JT
Supporting Vendor
Christian
Supporting Vendor
Hi Everyone,
Just a reminder that we have the AlignIt Tools and Billet oil system improvement parts in stock if you're
working on your engine and need them. Same business day shipping.
Thank you,
Christian
Thank you,
Christian
