Replacement air dam: Has anybody?
tried Rhino lining?/Truck bed lining on these before installation?
I was given a new replacement front air dam when I made a local purchase of a car cover. My driveway is designed in a way that I scrape that front air dam everytime I back into the garage. The dam(no pun intended) thing looks terrible and I am considering taking the air dam to a truck shop and have it done in heavy duty truck bed liner to help with durability and asthetics hopefully. I hear they can even do these things in color. In my past Roush days, we used to have the bottom lip of the front fascia done in a colored truck bed liner and it worked out quite well.
Has anyone tried this?
Received 2,051 Likes
St. Jude Donor '13
I don't recall hearing of that method.
Keep in mind that the air dam is cheap and easily replaceable, so I don't worry when ours scrapes. I use it as a kind of "getting a little close to the underside of the bumper" warning.
Some people will trim a little (or more) off the bottom of the stock dam, which is probably the best solution if you feel compelled to do something.
Absolutely. That thing is going to scrape everywhere except on a flat track. It's less than 3" from the road on my F55 GS. The good news is my front splitter is still pristine .
I tried one of the aftermarket sets. The side sections are stiff plastic; broke the first time they touched my driveway. I then paid a little more for an OEM set which are much more flexible. They are holding up well to daily scraping.
Ever try taking the approach and departure at an angle?
Works for me.
I back out my driveway at the same angle I drove in. Initially, to determine correct angle, I had an extra set of eyes watching while slow and deliberately driving up to avoid air dam contact - no more inadvertent scraping. I use the same principle at any angled roadways, if scraping is unavoidable, it will be at least lessen. But to avoid the chance altogether, I have been known to take alternate routes.
To maintain air dam and all plastic in pristine condition, I use C4 by G-techniq - once applied, it will last for several years.
Works for me.
Ive tried all the angles and if I go very fast it doesnt scrape. But at a respectable back up speed, it scrapes no matter the angle.
You probably want it to be as weak as possible, not as strong. The more it flexes and moves, the less it's going to wear when it rubs. Also, something has to flex/give. You want the dam to flex and give, not your bumper or the mounting tabs/etc.
Seems to me, the go fast angle will be the one - but only if you can slow down enough to duplicate that.
