Fuel Air ratio?
Fuel Air ratio?
Going to get my car tuned and was wondering what is the best fuel air ratio for max power and what would be a safe ratio to ensure no problems like a lean condition at wide open throttle?
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
Depends. What do you have as far as mods to the car? Heads & Cam? FI?
Can't say much without some information.
Elmer
Elmer
Right around 12.5 seems to be the usually consistent A/F ratio I see. Give or take a 1/10. Given your mods.
FI is a different case.
There is no fixed A/F ratio. The computer is constantly adjusting it depending on load. Cruise is ideally 14.6 to 1, hard acceleration can be into the 11.00 to 1 range on FI cars..
Usually during a tune, the tuner will lean out the engine under WOT to where there is a little KR. Then they will fatten the mixture back up to where the KR is fully gone. That will then usually give you the most power for your car. When you're out of WOT, the ECM runs the engine at 14.7:1 using the O2 sensors to trim out the mixture.
So, as far as a number for A/F at WOT, I can't tell you a concrete number. Two of the above posts are in the ballpark. FI needs to be fatter 11-12.0 or the engine isn't happy. The more modded the car, the fatter the mixture to keep the ping away.
When you're tuned, you'll have the A/F number for your car, on that day, at that temperature, at that altitude. That's the only real answer for your question.
Elmer
Elmer
