Z06 bi-mode muffler valve rattle
I have Z06 bi-mode mufflers on my car, and now the valves started rattling at certain rpm ranges.
Is there any way to adjust these, or do maintenance on them. I tried looking for an exploded view drawing to see how they are constructed, but so far no luck in finding a drawing.
Any tips of suggestions are highly appreciated
Fred
Fred
It is probably not the valves rattling. The inside of the mufflers, Baffles start to come loose and rattle. Only thing to do is cut apart and reweld the loose baffle. It's common on high hp cars.
St. Jude Donor '08-'09
I had to do the same thing. While I was in there I closed up the prefererated pipe.
The bottom inside wall is what cracks and breaks and rattles from the exhaust pulses.
-Carl
I had the muffler mod done this Saturday, we had a good look at the sidewalls but didn't see anything out of the ordinary, tapping them didn't produce any rattles.
I will try tapping the outside with a hammer, if that doesn't reveal the source of the rattles it's another trip to the muffler shop
Thanks for the tip.
Fred
Thanks for the tip.
Fred
Received 2,061 Likes
Mine has the same rattle, but only around 1,000 RPM or less and only when the valves are closed.
Since the only time the valves are closed is when the wife is along, I haven't gotten too concerned with fixing the problem.
Mine now seem to have the rattle only when the valves are closed, which for now is most of the time. I had the muffler mod done last Saturday, only to discover that after the mod the car is WAY to loud for me. Even with custom made ear protection the noise is deafening.
I live in the Netherlands were there are many people on bicycles, the slogan "Loud pipes saves lives" doesn't apply when they die of heart-attack from me accelerating
I will make another appointment with the muffler-shop to bring the noise down to acceptable levels, a good time to inspect the bottom inside wall for cracks, breaks and rattles and put in a few extra welds.
Fred
Fred
My passenger side Z06 muffler rattles in the closed position. The problem on my car is with the vertical shaft that the actual butterly attaches to. It has too much slop that allows it to move up and down causing a metal on metal vibration. I can put my finger on it and apply downward pressure while the car is running and the noise goes away.
I don't have a permanent solution yet, but in the mean time I've used a couple zip ties to help take up some of the slack in the butterfly assembly. This has stopped the rattle for now.
I have the exact same tin can rattle on mine. Does the zip tie interfere with the actuator's travel when it opens/closes? It looks to me like you can't have both the rattle gone and use m2w ?
I have some .020 thick Teflon sheet at work that should make a nice u shaped thrust washer. It looks like it will take up about half the current vertical play/slop. Let you know if it is successful.
