Headers and Tune good for +40 RWHP increase on stock LS3?
#41
Here are my 3 2008 A6 graphs.
Bone stock
Then I added
1 7/8" Stainless Works Longtubes, 3" Catted (but gutted) X Pipe and C6Z Mufflers + Tune (Stock Air Filter, car trapped 122mph like this)
Then I added a Halltech MF103 and had it retuned on Saturday
Bone stock
Then I added
#44
More than likely dyno variances. A CAI isn't going to account for 25-30 difference in hp/torque. Dynos are good for tuning and comparing against yourself, other then that the track is a better judge.
#45
dyno
Here is my 08 Coupe/A6/2.56 rear, with approx 46k miles. I don't have any baseline dyno sheets but with the headers installed and untuned the initial pull was 381 hp.
Mods:
LG 1 3/4 super pro headers gutted cats
Borla Stinger ( 3" version from Z06)
Halltech KillerBee w/hive
I was told that with the fresh oil change it my be off a pony or two....until the oil was broken in.
Mods:
#46
This is my 08 Coupe/A6/2.56 rear, with approx 86k miles.
Mods:
OBX 1 7/8 headers, Borla 3" Cats 3" X-pipe (Z06 setup)
Z06 NPP
Vararam
Circle D 3200 Stall
396hp/393tq...unlocked
Mods:
Z06 NPP
Vararam
Circle D 3200 Stall
#47
My car put down 369whp on a Dynodynamics stock, added a Vararam (supposedly doesn't show much HP), headers 1 3/4" and NPP then 93 Tune and got to 418whp. I got a 60whp increase from stock, but that was moving to E85 as well. This a M6 though, so not sure if this helps.
Douglas in Green Bay
#48
I don't have a dyno# but I understand that if you know the weight of your car with driver and the 1/4 mile "MPH" there are formulas out there that can get your rear wheel "real world" HP within a percent or two.
My 2010 GS (A6) has went 122 MPH (not my record ET run) in the 1/4, total weight w/driver approx. 3570 lbs. Anyone have a HP# for this mph & weight?
2010 GS MOD SPECS.
1) 1 3/4" headers, no cats & 3" X-pipe connected to the stock (430 HP) mufflers. < save some money!
2) 93 octane DiabloSport "canned" tune.
3) OEM air assembly with oem paper filter that I converted to a CAI. < cheap
4) 160 stat.
Running on all four stock Goodyear runflats & stock converter.
2010 GS MOD SPECS.
4) 160 stat.
How did you do the CAI
#53
Check my old threads & posts for pics and How to. My best MPH is 125, check the "Bolt-On" GS list and I must say I don't think any GS or lighter standard body LS3 has went that fast with just those type of mods.
#54
I traded in the GS on a 15 Z06 but I took my complete CAI system off including the cutout shroud before trading the GS in. I live in Maryland, if interested and willing to pick up $150.
That way you could keep all your stuff stock. I went from a best "stock" record pass of 12.31 to a best of 12.01 with just this CAI.
PS: Have the headers and X-pipe too.
#56
Just Dyno'd yesterday:
I Live in California - hence the 4 Cat System, there was no baseline before I put the parts on, there was a street tune done to dial things in before the Dyno runs/tunning
2009 LS3 A6 with 2.56 Gears - VARARAM, NGK TR5IX, Taylor 8mm wires, 2012-2013 ZR1/Z06 Exhaust manifolds, 3" Catted Downpipes, 3" Catted X-Pipe into 2 1/2" NPP factory Mufflers
390.86 RWHP ( divide by .82 = 476.65 HP @ Crank)
387.36 RWTQ ( divide by .82 = 472.39 TQ @ Crank)
Thanks,Matt
Thanks,Matt
#57
Drivetrain lost has dropped on the newer cars.
From what I have been seeing lately the drivetrain loss on the newest cars are between 12-15%.
Example: 390 WHP divided by .88 = 443 HP @ Crank
#58
A6 vehicles divide by .82 for the Crank HP approx. 20% drivetrain loss (which mine is)
MN6 you divide by .86 for the Crank HP approx. 15% drivetrain loss
Thanks,Matt
#60
Here is my bone stock, 13 grandsport dyno. It's a m6. The green line is after the ganitelli wire install. Wonder what it will make now after the z06 air intake, and the headers, full exhaust, and tune?
