Changing Fluids
Old 08-17-2013, 07:05 PM
TurkeySlugger
TurkeySlugger's Avatar
Default Changing Fluids
I will be changing out brake fluid, diff fluid, and tranny fluid. Was wondering how much was needed per and which fluid you guys prefer. Thanks
Old 08-17-2013, 07:18 PM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
And you have how many miles on what car with which trans?
Old 08-17-2013, 07:39 PM
TurkeySlugger
05 manual with 50000
Old 08-18-2013, 01:43 AM
HOXXOH
HOXXOH's Avatar
Any decent brand of DOT 3 brake fluid is fine. Do not let the reservoir go dry at any time.
I can't suggest for the trans.
Unless you're experiencing chattering in the dif, don't bother changing it for another 50-100K. If you do get chatter, then use 2 quarts of the latest fluid at the dealer that has the correct amount of friction modifier already included.
Old 08-18-2013, 01:12 PM
TurkeySlugger
the reason for changing everything is im the 6th owner and i have no clue how anyone else prior to me drove the car. it wont hurt anything to give her clean fluids
Old 08-19-2013, 02:40 AM
Gering
Tolero Apto Victum
Support Corvetteforum!
Gering's Avatar
I change all fluids and filters every 30K miles or every March.
Old 08-19-2013, 05:04 AM
hefti2
hefti2's Avatar
AFAIK diff takes around 3 qts of 75W90 with LSD modifier. Most of the people here swear on the OEM stuff but other stuff of comparable mixture is fine. I am using MOTUL full synt stuff.
For the tranny it is around 5 qts of ATF Dexron III stuff. The brand is up to the owners taste.-You can either go the OEM route as well or use some Royal Purple, Castrol or or or as long as the spec above is maintained.
But in order to get the correct filling it is important to:
1. drain both liquids
2. Fill in the new oils until it driples out of the filling holes
3. Have the rear wheels in the air
4. start the car, go into gear and let it run with spinning wheels for a minute or so
5. add oil until it driples out again and THEN you are all set.
If you skip step 3 and 4 you have filled in too less.
Regarding brake fluid:
I know in the States DOT3 is still very popular, so basically this is fine for a street driven car. However if you are going to a x-auto or similar event from time to time I would consider flipping it against DOT4 or (like I have) DOT 5.1
fluid.
DO NOT USE DOT5 since it is not compatible with the other three types!
Hope that helps!
Old 08-19-2013, 06:22 AM
timd38
timd38's Avatar
The owners manual is your friend. If you don't have it since you are owner six or seven, you get a free PDF of it.
http://www.chevrolet.com/content/dam...tte_owners.pdf
Old 08-19-2013, 01:11 PM
TurkeySlugger
hefti2 thanks that helped alot. will be using this when i am able to get back to the car. timd38 the link didnt work.
Old 08-20-2013, 01:40 PM
Homeboy77
Homeboy77's Avatar
Here is a link that worked.
http://www.c6registry.com/technical/manuals/2005OM.pdf
Old 08-20-2013, 03:10 PM
TurkeySlugger
sweet
Old 08-21-2013, 02:18 PM
hefti2
hefti2's Avatar
Pleasure! 👍
To Changing Fluids
Quick Reply: Changing Fluids
