Headlight lenses replaced...what a facelift
Cruising
Did a lens replacement this weekend. Can highly recommend that you do the same if you have crazed or scratched lenses.
Some pictures.
Before:
After:
Thank you RLSebring for providing me with new lenses.
Some pictures.
Before:
After:
Cruising
Taking the the bumper off, loosening the fenders and getting the headlight out is no real issue if you take your time work smart.
The more room you have the better. And if you have the opportunity to take both wheels of.... plenty of space to work. I could only get enough room in my narrow "storage" garage to take one wheel of.
When it comes to taking apart the HL assys... It gets trickier.
It´s a matter of getting the right temperature for the glue to "soften up". Only went up to about 120 degrees C (250 F) on the first one I did and had to struggle a fair bit to get the assembly apart. Went up to 150 C (300F) on the second one....much better. Then pry the lens apart from the housing with two flathead screwdrivers.
Then just remove the glue from the "channel" (a real pita). I used pliers and a hairdryer and rolled up the rubbery glue.
Clean everything really good...double check. Blow everything clean and glue + clamp the parts together again.
It´s probably not a job for everyone. But a experienced DIYer could pull it of no doubt.
Cruising
Cruising
The "heatgun" you see in the picture is actually a hairdryer....If you use a heatgun, It´s harder to get the adhesive out in larger pieces (tried a heatgun also). Too hot and it will crumble and tear off, to cold and it won´t come out at all. My experience is that a hairdryer in the hottest setting is closer to the "golden" temperature than a heatgun in the coldest setting.... (all depending on what kinds of guns you have obviously).
Cruising
Lense replacement
Why not avoid all of this by initially putting on the XPEL lense covers.
Put them on my 08 and after 5 years absolutely still perfect.
This case was after the fact I understand. I would suggest lense protection on the new beauties. Have no afiliation with XPEL
Cruising
Will definitely have a look at those XPEL covers though...to protect my new ones from scratching. Thanks for the tip!!!
And maybe the Crazing is mostly the cause of Euro-type parking light bulbs sitting to close to the lens heating it up to much...some believe that might be the case?
Isn't there some kind of "aerospace" coating on the lense that will be removed along with the haze during wet sanding? I did this to a Sebring, turned out great, but the lense is cloudy again after only a year.
Received 4,499 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Looks great!
Cruising
But if that coating doesn´t hold the lens clear for more than one year..... sure hope they don´t use it for the aerospace industry
Too bad about your lenses, that´s not a good report at all. Hopefully mine will hold up longer....but who knows....
Tolero Apto Victum
I have heard that a few times before. I clean mine with eagle one quick detailer. It is not hard on the lens and makes them look great. Over time mine are starting to look like the OP's...
Supporting Vendor
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Actually you might be right, and If so, wet sanding would not be such a great idea
I put one of the first sets of lens on mine back in 08 when I did the carbon lights. They are starting to show some crazing now. I think 5 years is going to be a norm, so longer some shorter.
