Removing the two rad fan wires (red/black) from module connector?
Old 10-08-2013, 03:08 PM
DSOMC6
DSOMC6's Avatar
Default Removing the two rad fan wires (red/black) from module connector?
Fan wire shorted from getting pinched between the module and the thicker G1 swaybar. Electrical tape resolved it for a couple weeks.
I have the plastic lock/slide removed.
Gave a slight tug on the wire(s) but it's obvious to me the spade is clipped in place inside the plastic housing.
Where do you push-in to release the wire(s)?
I already hard-wired the top portion when that connector failed so I cannot pull the wires up/down by simply disconnecting the two.
TIA
Edit: My vision sux from 6" away... looks like I need to round up a smaller tip screwdriver and insert at tab on flat side of connector....
Quick Reply: Removing the two rad fan wires (red/black) from module connector?
