Track Day tire pressure
Hey guys I have an 08 C6 Z51, looks like I'm going to be able to hit the track before this year is over after all...I just bought BFG G-Force Sport Comp 2 tires...does anyone know the optimum run hot tire pressure for the track with these tires (stock C6 sizes)...I cant find this info on the BFG site...Ive read that some just run 26psi up front and 28psi for the rear to start with then keep them below 31psi via monitoring after each session of laps...any advice would be appreciated, thanks.
If you're talking about a roadcourse track you will see them go to 38-40 psi hot. I would keep them at 38 hot and if I saw the left front (If running clockwise) go to 40 or something I wouldn't even worry about it. Above that is probably too high as the tread crowns in the center of the tire reducing contact patch size and you won't have as much available grip. Bleed them off to 37 - 38 as soon as you come into the pits and you should be fine. They have a max inflation pressure of 50-51 psi and I doubt you will ever get close no matter how hard you drive it unless you started cold pressures in the low 40's for some reason. I have found that until they get crazy high in pressure street tires usually give predictable grip levels even at slightly differing pressures and don't really need to be warmed up like a Hoosier or a slick. Great time to work on car control. Smash and go. Looks like it's made to do well in the Wet and the Dry. Hope you like it, be careful and have fun!!
