2010 grand sport shroud mod?
Ok I have found a post on the free air mod. The guy said it is done from underneath the car. I can't get to the shroud from underneath????? Help please.
Why do you want to cut it? Unless you're putting in a CAI that needs it cut, just pin it back. That way you get a better effect--outside air coming straight in through the grill and angling up following the curve of the shroud rather than air mixing with the heat from the condenser/radiator. It's not a big temp diff, and both work, but if the coolest air is what you want it comes in from the grill directly to the filter, not the back of the shroud.
After finding some post I don't want to cut I just want to prop the bottom open but I can't get to it from the bottom of the car. I took the stock air intake out and I can't get to the two pins from the top either and I didn't want to tear the shroud up by trying to rip the plastic pins out.
Any pics
From your profile pic OP, it looks like you have a C7. This is the C6 tech forum, and there are quite a few differences between the C7 and C6 intake, just sayin....
edit - OP, I just looked at your profile, you need to start paying more attention!!! Get over to the C7 forum, haha !!!!
November 2013. Wonder if the OP ever did the mod before selling........
It kills me that the mods can't automatically lock threads if they are over 6 months old, or something like that........
