Alignment Specs
Alignment Specs
Does anyone have the specs for an alignment. The GM specs and the Phadt specs for street driving. I wanted to see the difference as my tires are wearing on the inside.
Tons of info around the forum if you do a search. Here: http://forums.corvetteforum.com/c6-c...t-2012-gs.html
Post #9 shows the GM specs, and post #16 gives the Pfadt specs, which are within the GM specs but with tighter limits. I think you could go with a bit less front camber than what is shown--more like -0.6 to -0.8--to minimize wear if you're not looking for maximum grip...
My GS is supposed to be notorious for poor tire mileage. Since I'm an hpde addict I replaced the eccentric camber adjusters with the Pfadt camber kit and had the wheels aligned to the Pfadt street performance. The specs are basically factory, just a tighter tolerance. The alignment is expensive because of the extra labor involved but I don't worry about camber adjustments changing. I had the motorsports shop take most of the toe-in adjustment to pretty close to 0. So far I have 13k miles and 7 track days and still have tread left. The issue I ran into is not enough camber, I'm wearing the outside of the tire not the inside. Its my contention toe adds more tire wear than camber and camber needs to be set properly to keep the tire flat during turns. With street tires I'm a little over 1g in the turns and need to add more camber to keep the tire flat. I'm at -.7 to -.9 and will adjust for -1.3f and -1.0r. With a flatter tire,my speeds and GM's in the turns should go up a bit too.
