Valve cover gasket leak
The valve cover gasket is leaking on the passenger side, ever so slightly...I've NEVER changed valve cover gaskets before so I'm a bit timid of doing it myself but want to try and knock it out this weekend or next. Anything special I need to know? Any help is greatly appreciated, thank you in advance!
not really
Re-tighten anytime is fine. The TQ spec for the bolts are 106 inch lbs... Make sure you have that and you should have no problem. Never guess when tightening. Always use a tq wrench...
Ok so re-torqued around 5am, been driving around, still slightly seeping under the actual valve cover gasket. They are Felpro for what it's worth. Is there a pcv valve to check, or how do i go about checking crankcase pressure? Right now just going to go buy new gaskets and see if that works, if not then new valve cover(comes with new gasket i believe.)
You might want to give it just a bit more time...the gasket is soaked and as you squeeze it more by retorquing, some oil will squeeze out and appear as a continued leak.
Also I noticed my oil filler cap has a tiny bit of play, would that have any effect on the leak?
Got it, thank you. I'll hold off for the week before just ordering a new cover/gasket. In my head I'm thinking the LS7 exhaust manifolds I put on may be putting out too much heat but I have no clue. Thanks for the response.
After I reworked my OEM valve covers, although my car has low miles, went ahead and changed out all the gaskets (four under the four cover bolts + the cover) with OEM gaskets:
Few years now. No leaks and I don't expect any leaks.
FYI: modern OEM synthetic valve cover gasket doesn't soak oil. If there is still leak, after dissembled, cleaned and retorqued - something else is causing the leak!
