LS2 gained 5hp with FAST 102? HELP!!!
Old 03-14-2014, 07:37 AM
  #41
brightc6
brightc6's Avatar
[QUOTE=FederalPerformance;1586396923]What the hell is a V Max ring?
It is a ring that slides into the mouth of a FAST 102 to make the opening the same as 90mm throttle body. Supposed to be a drivablity thing...who know, it was free lol.
Old 03-14-2014, 07:40 AM
  #42
brightc6
brightc6's Avatar
Originally Posted by dennis50nj
I have seen a couple run very smooth, and the dyno was lower then expected they found a bad injector, i have seen broken valve spring with no signs of a miss just a lot slower et
How do i check for bad injector? i get the valve spring part because i can just pull off vavle covers and look. BTW car only has 40k miles.
Old 03-14-2014, 10:16 AM
  #43
FloydSummerOf68
FloydSummerOf68's Avatar
My Auto C6 LS2 made 397rwhp with the following....
Intake, Ported FAST 90, Catless Longtubes, 25% UD pulley, Borla Exhaust
I'd expect to pick up around 50rwhp with a decent sized cam and would've put me right on target with your numbers.
Does the car FEEL faster? I'm skeptical of the initial numbers.
Did you ever run it at the track before? Run it again and compare the MPH.
Old 03-14-2014, 10:33 AM
  #44
dennis50nj
dennis50nj's Avatar
their are a lot of different ways, one way is with a temp laser gun, check the temp at each exhaust port, header tube, no fuel, no flame, no heat, could be injector or spark, then check plug. swap that injector with one on the other side and see if that port runs cooler.
Old 03-16-2014, 07:54 AM
  #45
timd38
timd38's Avatar
Originally Posted by tennblkc6
an over priced tornado
I don't agree with you on the V Max ring. If you have a 92mm throttle body and 102mm intake, it smooths out the air flow instead of having a step that the air has to go over.
If you believe that it doesn't work, then you have to assume porting the intake does no good either because porting the intake also smooths out the flow inside the intake.
Old 03-27-2014, 09:07 PM
  #46
brightc6
brightc6's Avatar
Well took the car to the track and ran the same ET and MPH as before FAST intake install.
Any ideas?
Old 03-27-2014, 10:06 PM
  #47
tennblkc6
tennblkc6's Avatar
sorry I don't have any answers for you. however, if you decide the 5-7hp you picked up with the fast install wasn't worth the $ let me know if you would like to sell it and recoup some of your $$ back.
Old 03-28-2014, 11:21 AM
  #48
dennis50nj
dennis50nj's Avatar
Any ideas?
what was the difference in the DA ?, get a new tuner. get rid of the v max ring, you are the only person that i have ever heard of with such little gains from the fast.
Old 03-28-2014, 12:14 PM
  #49
C7&7
C7&7's Avatar
I am standing by the numbers were too high to begin with. Your numbers are where they should be with your mods. My car actually made less and it was a MN6.
Old 03-28-2014, 12:16 PM
  #50
tennblkc6
tennblkc6's Avatar
Old 03-28-2014, 01:14 PM
  #51
dennis50nj
dennis50nj's Avatar
that could be true, but why no gain at the 1/4, should have seen 2-3/10s
Old 03-28-2014, 03:14 PM
  #52
Justasheet
Justasheet's Avatar
I bought one and it made my car run worse. Maybe a tune is necessary after installation. I removed it and the car ran fine. I was able to return it so no harm done.
Jeff
Old 03-28-2014, 04:49 PM
  #53
dennis50nj
dennis50nj's Avatar
this makes no sense to me, now if it was a 102 going into a 92 that would.
Old 03-28-2014, 10:44 PM
  #54
brightc6
brightc6's Avatar
I tried to listen to everyone telling me my numbers were wrong to begin with so that is why I took it to the track. I actually think the car slowed down. the track was 1000ft not a 1/4. It ran 9.73 on street tires, took it back with FAST102 and MT drag radials and car ran a 9.71. The number are not wrong.
Old 03-29-2014, 08:45 PM
  #55
dennis50nj
dennis50nj's Avatar
what was the dates and timeslip of both runs, can you post the complete slips naming the date and time of the runs
Old 04-15-2014, 12:55 PM
  #56
dennis50nj
dennis50nj's Avatar
You win the award for the slowest fast intake LS motor
Quick Reply: LS2 gained 5hp with FAST 102? HELP!!!
