(+) Battery Nut & battery Scissor clamp
I lost my positive battery cable scissor clamp, and the nut is so corroded it can't be salvaged, does anyone know where I can purchase a scissor clamp & nut without having the buy the entire positive battery cable assembly?
St. Jude Donor '12
How did you lose the clamp? It is crimped to the positive wires. If you just need the cone nut, you can find it on ebay. If you want a new clamp consider replacing out with aftermarket. I replaced mine with a stinger hpm series clamp from darvex. Very nice and holds the battery terminal securely. The wire harness is about 100 and not particularly ready to replace. Will have to drop the starter and possibly a portion of the exhaust.
