Anyone plug their oil filter bypass?
Supporting Vendor
I was researching and found quite a few performance and race engine builders plug the oil filter bypass so that only filtered oil goes through the engine. They say you have to make sure you change the filter regularly and warm the engine oil up before going over 2500 rpm. I was thinking about doing this but want to hear from the pro's here on the forum not the ones that say don't mod anything on a Vette.
Anyone have experience with this mod?
I am running a external oil cooler with a thermostat and remote oil large filter on my C5Z 440ci n/a ls2.
Christian
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Seems like a bad idea. The bypass is there to keep oil flowing should the filter become restricted. At extreme high psi (cold engine with high flow oil pump) it keeps the filter from exploding/blowing off.
Supporting Vendor
Thanks for the reply.
Ya, I read that too. That's why they said you have to service the filter regularly and run a high quality filter like WIX or some other performance filters.
Just doesn't seem like a good idea to run unfiltered oil through the engine.
I bet unfiltered oil is way better than no oil. Hopefully metal will sink to the bottom of the oil pan anyhow, mostly.
SUBVETTE
With a clean filter how much oil goes through the bypass? I don't know the answer, but I would bet it isn't enough to be concerned about. Seems like plugging it is a dumb modification to me.
From another prospective. Even having regular service, no telling if the filter was not an lemon, proves it is, in an most inopportune time.
One thing can help to capture some of the metallic particle is using purpose designed, high temperature resistance magnetic drain plug and stick a few on the filter housing to aid. My recent drain proves the benefit from an newly built:
After slurry removed:
I've done it regularly on gen 3 SB but I consider it ' big wup ' now. The oil filter will withstand the pressure of 90% of the oil pumps out there and clogging is not an issue.
In the end its not big deal either way.
Supporting Vendor
I have decided that I am going to plug the bypass and run a dual filter setup so only clean oil can flow freely. I think the bypass opens more often then we think it does. Especially after seeing how much metal the magnetic drain plug catches, I don't want it going through my engine.
Thanks for all your input!
Christian
Christian
I'm not sure about the GM LS filters, but the K&N filters that I use on my car and truck have an internal high pressure bypass. Not sure what the bypass pressure is though. In any event, if you are careful with warming the car up and especially if you are using a remote dual filter setup and you monitor oil pressure to see if there is any inordinately high pressure, your engine will be fine with the bypass blocked.
I've run several big blocks over the years with the bypass blocked - all with remote filters though - and I think the bearings were much better off for it. The thing with the bypass is that you don't know how weak the spring is, because there's no real way to monitor when the oil is bypassing and how much oil is bypassing.
I also like to run magnets in the sump and on the filter too though, because a lot of oil gets splashed around in the bottom end from windage, so the cleaner the oil stays - even before it gets to the filter - the better.
This idea may just be responding to a problem that doesn't exist. It may be that doing this will extend the engine life from 300,000 miles to 350,000 miles...neither of which will ever be seen. The only way to know if the bearings are better off is to disassemble the engine and measure them, or see them wear out. Again, neither of which is likely to happen.
Supporting Vendor
Supporting Vendor
[QUOTE=CI GS;1588523154]I'm not sure about the GM LS filters, but the K&N filters that I use on my car and truck have an internal high pressure bypass. Not sure what the bypass pressure is though. In any event, if you are careful with warming the car up and especially if you are using a remote dual filter setup and you monitor oil pressure to see if there is any inordinately high pressure, your engine will be fine with the bypass blocked.
Supporting Vendor
Christian
Christian
Received 2,061 Likes
