Fuel Line throough Fuel Rail Cover
Old 08-18-2014, 09:34 AM
DKS
DKS's Avatar
Default Fuel Line throough Fuel Rail Cover
Having never done this, how do you disconnect the fuel line that goes to the fuel rails? I would like to disconnect it at the fire wall so that it will slide threw the Fuel rail Cover.
Thanks!
Old 08-18-2014, 09:59 AM
Dano523
Dano523's Avatar
Received 3,020 Likes on 2,175 Posts
Autoparts store to pick up fuel line coupling disconnector tool,
Ridge side pointing back away from the fire wall around the hose in front of the coupling on the fire wall side, push the coupling forward toward the firewall, push the tool ridge edge into the coupling to push the coupling connector rings inwards away from the firewall, and the coupling will pull straight back off the line.
To put the coupling back on, you don't need the tool. Just push the coupling hard forward onto the line, and the coupling inner rings that you released with the tool to pull it off, will lock back on the tube end on their own.
Old 08-18-2014, 10:49 AM
jim2092
Support Corvetteforum!
jim2092's Avatar
St. Jude Donor '08
System under pressure - fuel will/may come out so have rag/towel under the connection.
Old 08-18-2014, 03:54 PM
cclive
cclive's Avatar
The FRC can be removed easily without disconnecting the fuel line. Do it when the engine is fully warmed up and it will be flexible like a noodle. This is why they made it with a slot.
Old 08-18-2014, 07:05 PM
RoadReady
RoadReady's Avatar
But you can help your chances by edging the line slot with masking tape.
Still, consider my sig—
Old 08-18-2014, 07:11 PM
timd38
timd38's Avatar
Hot and tape or it will scratch or crack.
Old 08-18-2014, 07:17 PM
cclive
cclive's Avatar
My FRCs are painted silver, so I wrapped the fuel line with blue masking tape to keep from scratching when it slides through the slot.
To Fuel Line throough Fuel Rail Cover
Quick Reply: Fuel Line throough Fuel Rail Cover
