Brey Krause Tow Hook on an NPP C6 GS
http://www.bkauto.com/category_s/172.htm
Anyone out there mount one of these tow hooks on an NPP exhaust equipped C6?
Cheers - Major Boyd
Cheers - Major Boyd
Received 8,928 Likes
I don't have a BK but one that is similar. It is a major PIA. The plate is fastened to the two inner bolt holes that are used to hold the muffler hanging bracket in place. The muffler, rear fascia and the muffler valves will cause grief, cut fingers and a strong blue atmosphere. Send the kids to a movie.
Bill
Bill
Bill
Bill
I installed a Pfadt tow hook, mounts the same. Talk about a MAJOR PITA. Had to take the mufflers off the hangers, and loosen the tubes to be able to wiggle them enough, and even then just barely. Took two of us and literally right around 4 hours of swearing and rolling around on my back every which way to be able to get the nuts started, and finally finish the "easy" install. I didnt have a lift to do it, so that might make it easier, and doing it without th mufflers installed would definitely make it easier.
Good luck, have fun, be prepared to be frustrated.
I spent about 1 hour installing a similar hook on my Vette with the NPP exhaust.
I not really sure how the bolts found their way back into the frame, but I used more positions than are included in any sex guide.
Oh, and the bolt pattern for a regular C6 is a different width than for the Z06 or ZR-1, I found that out the hard way.
Didn't know that...........hope it will fit my Grand Sport. It is similar to the Z06 dimensionally , so maybe it will fit.
Yes it fit. Easy if you have the rear diffuser removed, which I did to install my 5 point roll cage. With my lowered car hooked up with ZR1 splitter and side skirts, the tow hooks are mandatory. You'll never get my car up on a flat bed tow truck without these tow hooks. If you try you will be buying new carbon fiber aero parts. The track I use requires tow hooks also.
Cheers - Major Boyd
Cheers - Major Boyd
It's not rocket science guys! Use a set of jack stands to push the muffs up slightly to ease tension on the hangers. An extension with a swivel on it is your friend. Oh - wear gloves to.
So easy, a caveman can do it!
Please post a pic of your installed tow hook.
Thanks.
My screen name is GM Tech 'cuz I graduated from the GM co-op engineering program with a BS in Mechanical Engineering in 1962. The school in Flint, Michigan is now called Kettering University.
I've wrenched for a lot of years and even had the pleasure of working a project with Arkus Duntov. Your input is welcome, but I didn't state the issue properly, so I got the answer you provided.
Cheers - Major Boyd
I'm late to the party but for future reference if someone does a search, the dimensions are the same between the base, Z cars, and the GS. It's the reason you can bolt on NPP mufflers to a base car or GS not originally equipped with them (albeit with a midpipe change for the early base cars due to the angle of the midpipe ). Likewise you can bolt up a Z06 or ZR1 bi-modal exhaust system using all the factory mounting points as well. My '13 GS has a mix of '12/'13 LS7/9 exhaust parts from the manifolds to muffler tips. Bolted right in
