Help - only using half a tank of gas after pump and sender install
c6reaperx
After i installed a new fuel pump and sender in both tanks, I only get half a tank on the gauge. I know that both tanks are full, I filled up with 17 or so gallons.
All the hoses are connected. I have double checked the electrical connections. Is it possible that the fuel is not being used from the pass tank because it is not reading any fuel? I am wondering if I have a stuck float.
Any suggestions are welcome, the car is driving great.
You got the wrong sensor!!!! Take you vin# with you to get the right sensor. My tanks have been out 4 times now! My car is 07 that was built in late 06. GM mixed alot of parts. My car has been down for 2 months! Thanks GM
c6reaperx
c6reaperx
So I replaced the passenger side sending unit and i'm getting the same thing. Is it possible that I reversed the wires on the drivers side unit? I'm going to try and reverse them at the external harness and see if that works. If not I'll be dropping the drivers side tank.
For the first couple model years, the sensor range was approximately 40 ohms (empty) to approximately 250 ohms (full).
If the sensor got dirty, electrical resistance would go up, causing the gauge to err in the full direction. That's not good, so GM reversed the range somewhere around 2007, so a dirty sensor would cause the gauge to err in the empty direction.
Place a multimeter across the sensor wires and check the resistance. With the car full of gas you should see ~250 ohms.
