Cmc-30 cam
I would do the converter first in an auto. Listen to Joe! He's always extremely helpful and will steer you away from unnecessary mods or at least point you in the right direction.
Supporting Vendor
10.9 @ 131 I believe
I put a stall in after and ran a best of a 10.80... although had some more tuning to do so I don't know how much better I could have done.
I've not seen a stock converter n/a car get 10's that's great! Do you have a thread or details on the mods? The stock converter is very limiting on the 60 and that's hard to make up even with a lot of HP.......
Supporting Vendor
You can get 10's with a stock cam with a decent stall, many have done it.
idle clip:
and some acceleration:
2010 Corvette Auto - Mods were:
AirAid Intake
Kooks 1-7/8" Headers with Offroad Midpipes
Ported Intake manifold (maybe - I can't remember if we only did it to my 08 manual)
Custom CSP Stock Stall Camshaft
Milled Heads
Electric Water Pump
and UDP
To break into the 10s we did mill the heads about .020 I believe as without milling the heads we were running 11.1 or 11.0's.
My only true mistake with the build was I put a UDP on it. So at the low idle I had it set at, it would not spin the alternator fast enough to generate proper voltage.
The car's powerband was tremendous. And would regularly pull 1.7 60's on the stock stall. With the FTI 3200 stall I think I pulled 1.6's... I don't believe I ever got a 1.5 off of it, but I didn't have it in long before I sold it - which is why I think I could have done a hair better with some more tweaking.
I've made slight adjustments to the cam and it brought out some more horsepower with no sacrificing low end on customers cars.
I posted my best ET time slip somewhere on here I believe under my personal screen name (AndrewZPSU) before I was a sponsor.
__________________
www.cspracing.com * Complete Street Performance * CALL US 610-628-1563
And don't forget to Like us on Facebook and follow us on Instagram @completestreet
very nice numbers. Ive thought about it, and Im gonna do the torque converter! Since I am doing the verter im going with the CMC-40 CAM, minus well go big. I wonder if I can use that cam with a blower? does anybody know? Im going with the kooks 1 7'8s, with 3 inch pipe=2.5 outlet, i.e in the future il just switch the x pipe to a full 3inch. ECS system or procharger. It has taken me a long time to make up mind guys, after reaserching all these diffrent options for my car. Il call john monday and ask him to verify. thank you guys for the great input
Received 2,263 Likes
C4 of Year Winner (performance mods) 2019
My advice is if you're thinking about a blower, do it! I love mine, and it makes way more power than any cam will without the drivability issues. The money you'll spend on cam & headers is getting very close to centri blower cost, and you'll make significantly more HP with the blower on an otherwise stock car than with cam and headers. If you do stick with the cam, the CMC-40 will work win a blower, but won't be optimized for it. If you're in Dallas, PM me and I'll take you for a ride in my blown GS.
Here is my old thread. Cam sounds excellent, Performs like it sounds, Very streetable with stock stall, And loves the N20.
Car went 150 MPH at a local runway event
https://www.corvetteforum.com/forums...am-update.html
Track Run
Track Run
#33
I believe his is a Vortech! I sold that orange car i posted above and now have a white c6 with an ECS kit on it and it makes 660 through an A6 with a bone stock motor. Blowers are awesome
#34
Just let me know when you're coming down, be happy to show you around. If we're talking flywheel, I'd figure the car is making about 650HP. It dynoed 575RWHP on it's 5th run on a hot/humid day. It's an A&A kit with a Vortech V3-Si (the smallest they do for the Vette).
