Corvette C6R replica
Gents,
I have 06 z06 that I'm slowly transitioning into a C6R replica, at least appearance only. Looking for a place that I can get the same appearance for my headlights that look just like the C6R headlights.
Pic#1: My z06
Pic#2: my current headlamp
Pic#3: what I want my headlamp to look like.
Please note in pic #3 how the black border follows the lexan outer-edge light cover. This is the piece I am looking for to sit flush-mount with my fiberglass body lamp housing. I don't need the black bezel, just the lexan light cover that looks like pic#3.
Any help?
Pic#1: My z06
Any help?
Where do I get a new lens that fits snug directly to the fiberglass body? I've been told I could paint the inside cover of my current lens but I still need it to fit snug directly to my fiberglass.
You can buy a flat piece of yellow lens and make those for less than $25.00.
If you look closely (at the C6.R) the lenses are screwed on covers. You can see the screws evenly spaced around the edges.
Make a template of the clear lens that's on your car, lay it flat on your yellow lens material, then cut your pattern..........lay it on top of your clear lens and screw it down........nice, even and flat!
If you're a perfectionist, like me, it will be perfect. It's not rocket science.
BTW! I'm doing the same to my car.............converting it to a C6.R replica. Where did you get those decals from?
As for making my own lens, the C6.R lens is curved. I would need polycarbonate lens that is curved to the right curvature. I also want them slightly larger than the stock lens because the C6R lens fits snug against the fiberglass body. I don't think your idea can be easily done without considerable training in working with lexan, plastics, or polycarbonate.
Yes; I know they're curved. Come 'on man!
You can buy the material practically paper thin and it will mold perfectly to the oem lens. Enlarge the pic and you will see how the team made the cover fit with screws. It happens to be a clever idea because it's cheaper to replace the cover than an entire molded lens. That's how race teams do it bro.
.............you could also have a tint shop shrink yellow film on the outside! :-)
Now you're beginning to making sense. Telling me to buy flat plastic in your first post doesn't really explain to much, instructor...
Tell me more, ie what type of material, where I can find it, how to curve the plastic (this isn't flimsy material your elementary stencil is made out of), how to secure it to my figerglass body etc...
...........secure it to the fiberglass body? Now I'm confused! I thought you just wanted to have yellow lenses. What are you trying to do? Remove the lights and cover the holes?
Here's one vender for you:
http://www.eplastics.com/Plexiglass_Acrylic_Sheet
.125 is the thinnest I found:
http://www.eplastics.com/Plastic/Col...80-125CCM24X48
...........or you could try your local hobby shop or search flee-bay!
However, I feel your cheapest route would be tint.
My original suggestion would be the best for what you are attempting to do.
However, the C6.R is designed for those type of lights. Our street cars are NOT the same. Notice the two bulbs? I don't see how you can cover the gap on a street car without having a slightly mess. Covering the lens is easy, I'm not sure about the gap.
Good luck and keep us posted. I'll post up when I have mine done.
Remove the lens, paint the covers black and then use a yellow tinting film or yellow tinting spray
Film on amazon:
Spray on amazon:
EDIT:
With the smoked lenses youre going to need something to remove the black tint. or you can pm rl sebring for a new set of lenses...
also if you want to push the c6r look further, Glover design makes the fender vents, and Halltech makes a single vent hood
Good luck!
Film on amazon:
Spray on amazon:
Krylon 9024 Stained Glass Color Glass Paints Aerosol, 6-Ounce, Yellow Finish - Spray Paints - Amazon.com
EDIT:
Good luck!
Fog lights are the same way. your not gonna get rid of the gap. take a strip of black vinyl and do the border and then tint over the whole light. But if you getting that picky you need to fiberglass over you side markers and put stickers in their place.
Just call Pratt Miller and tell them you want to buy a pair of lenses.
I know they have spare because I know a guy that vintage races one of the real C6R's and when he wrecked it he had no issue getting parts.
Also I agree with the creativity used to get the decals, that was a slick idea!
Film on amazon:
Amazon.com: Metro Dark Yellow Vinyl Fog Light Lens Tint Film 24"x12": Automotive
Spray on amazon:
EDIT:
Good luck!
Film on amazon:
Spray on amazon:
EDIT:
Good luck!
