Any MSD 2step users? (8733)
For those who have used 2step on your stick cars, have you had luck with MSD 2step (part number 8733)? I have had n2mb 2step on my c5z and it was a pain in the ***, had to fine tune it and half the time I could have a better launch without it. I have a few friends in the new 5.0s who have consistent good launches with the msd unit. So for those who have it, how well does it function/perform at the track or the street?
Supporting Vendor
Does it work well enough for you to hook and hold traction? On my old c5z I had n2mb and it held the rpms at launch and after I release the clutch (after I hook) and continues to spin. I read the msd is a better unit.
Supporting Vendor
I'm not quite sure what you're asking because being able to hook and hold traction will be dependent on your tires and/or track prep, not on the MSD box. The function of the MSD is only to hold the engine at certain RPM and then once the car launches (either by taking your foot off the brake or releasing the clutch in your case), it's no longer being activated.
Supporting Vendor
Sorry I wasnt being clear. My problem with the old unit was it held the rpm at launch, but soon as I leave the line it goes back to wide open before the car catches traction. and at relatively low rpms. It didnt really control the rpms during the launch, only held it there, once I try to launch it goes back to 7,000 unless I half throttle it. Tires were 295/45/17 ET streets radials.
