Dewitts radiator z51 option C6 2005.
Hello guys, my radiator end tank cracked and rather then take a chance and replace it with another oem style one and have it do it again. I just bit the bullit and bought the dewitts radiator set up for the EOC and TOC coolers. I opted not to get the fan set up and just hope that my factory fan fits in it there with no issues. Any insight or things I should be aware before it comes here for delivery. I am also going to put a 180 degree thermostat in. My tuner said no need for the 160 degree.
The Dewitts is a really nice product.
I have dual fans but on the street they never ran more than 50% on the streets in traffic with ambient temps around 95.
My on track temps dropped 40 degrees.
Cutting out and splicing the fan connector would be a good thing to do while in there.
they info is buried in the service manual !
i spent quite a bit of time trying to find out why my 160 wouldn't keep at 160
2. The oil line that connects to the bottom of the left tank is attached to a boss on the electric fan housing with a plastic clip. With the DeWitt's radiator installed, the thickness of the plastic clip may prevent the line from clicking into its quick-connect fitting in the radiator. I just left the clip off and used a zip tie.
one thing that took me a while to find the temp of the coolant actually runs 21* above the stamped temp on the thermostat.............so a 160 runs about 180. The stock is 185 and runs about 205
