[VR] VENGEANCE RACING FALL SPECIALs
Former Vendor
Fall is finally here, and we're starting it off with HUGE SAVINGS on parts and service!!!
*Special Pricing for a limited time only. Call to reserve your appointment or place your order today*
VENGEANCE RACING PARTS SPECIALS
*ALL SALES CAN BE FOUND ON OUR ONLINE STORE*
GEN III - LS1 / LS2 / 4.8 / 5.3 / 6.0
SAVE $200.00 on ALL "Build Your Own" Heads/Cam Packages
CATHEDRAL PORT PACKAGES STARTING AT $2,079.99
SAVE $100.00 on Cam Kit + and Budget Cam Kit
VENGEANCE RACING CAM KIT +
Includes: Custom camshaft of your choice, VR dual valve spring kit, hardened pushrods, C5R timing chain, Comp trunion upgrade for OE rockers, Melling hi-volume oil pump, front cover seal and gasket, waterpump gaskets, ARP cam bolts, and GM crank bolt (3-bolt timing gear/LS2 damper available if needed)
VENGEANCE RACING BUDGET CAM KIT
Includes: Custom camshaft of your choice, VR dual valve spring kit, and hardened pushrods
SAVE $50.00 on ALL VR Custom Grind Camshafts
ORIGINALLY $399.99 - NOW ON SALE FOR $349.99!!
PORTED FAST LSXR 102mm Intake Manifolds - Starting at $899.99
UP TO $275.00 IN SAVINGS!!
LS1/2/6 | LS3/L99/L76/L92 | LS7 | LSXRT | 92mm
*FREE* Mounting & Balancing on ALL Wheel & Tire Packages
ORIGINALLY $25 PER WHEEL/TIRE!!
GEN IV - LS3 / LS7 / L99 / L76 / 5.3 / 6.0 / 6.2
SAVE $200.00 on ALL "Build Your Own" Heads/Cam Packages[/SIZE]
LS7 PACKAGES STARTING AT $2,499.99
SQUARE PORT PACKAGES STARTING AT $2,399.99
*FREE* VR Stainless Steel Brake Lines w/ Purchase of SET of Carbotech or Hawk brake pads
*5th Gen Camaro / C6 / C6 Z06 ONLY*
ORIGINALLY AN $89.99 VALUE!!
VENGEANCE RACING INSTALL PACKAGE SPECIALS
C5/C6 Corvette
VR/WCCH LS7 Cylinder Head Exchange Program - $3,699.00 INSTALLED & TUNED
$500.00 value!
Restore confidence and increase performance on your LS7 valvetrain with the Vengeance Racing cylinder head exchange program.
Includes: WCCH Stage II CNC Ported cylinder heads (exchange), dual valve spring kit, head bolts, head gaskets, labor, and tuning
SAVE $250.00 when you purchase any ARH longtube header system with installation!
C5 AND C6 ECS or A&A SUPERCHARGER KITS - INSTALLED & TUNED
STARTING AT $7,499
C7 Corvette
$500 OFF ALL C7 PERFORMANCE PACKAGES
SAVE $250.00 when you purchase any ARH longtube header system with installation! (Cannot be combined with Performance Packages)
4th Gen F-Body
LS1 F-Body BUDGET CAM KIT - $1,799.99!!!
Includes: VR Custom camshaft of your choice, VR dual valve spring kit, hardened pushrods, NGK spark plugs, front cover gasket & seal, fluids, and street tuning
5th Gen Camaro
5th GEN CAMARO ECS SUPERCHARGER KITS - INTALLED & TUNED
STARTING AT $7,999
WHIPPLE SUPERCHARGER SYSTEM FOR 5TH GEN CAMAROS - INSTALLED & TUNED (Whipple Tuner)
STARTING AT$8,999
CTS-V / ZL1
**$500 OFF ALL STAGE IV and STAGE V PERFORMANCE PACKAGES**
**$250 OFF ALL STAGE II and STAGE III PERFORMANCE PACKAGES**
**$100 OFF ALL STAGE I PERFORMANCE PACKAGES**
Trucks / SUVs
PROCHARGER
1999-2003 TRUCK AND SUV - INSTALLED AND TUNED
STARTING AT $6,699
2003-2006 TRUCK AND SUV - INSTALLED AND TUNED
STARTING AT $6,999
2007-2014 4.8/5.3L TRUCK AND SUV - INSTALLED AND TUNED
STARTING AT $6,499
2007-2014 6.2L TRUCK AND SUV - INSTALLED AND TUNED
STARTING AT $6,199
WHIPPLE INDUSTRIES
GEN V 5.3L TRUCKS 2.9 WHIPPLE - INSTALLED & TUNED (Whipple tuner)
STARTING AT $6,699
GEN III & GEN IV 4.8/5.3/6.0/6.2 TRUCKS 2.3 WHIPPLE - INSTALLED & TUNED (Whipple tuner)
STARTING AT $7,499
Former Vendor
Yes sir we would be happy to supply the Trickflow LS7's with your package. They have recently been added to the package online, but also feel free to call us at any time if you would like to discuss your options and place an order. Thank you sir!
