Unbeatable Prices on Mcleod Clutches Garaunteed & It Ships FREE @ Hinson Motorsports
Former Vendor
-Lighter than stock pedal feel
-Bolts to stock factory flat flywheels (LS1/LS6 only)
-Easy Installation
-Organic & Metallic disc facing available for smooth & even engagement
-Smooth engagement with excellent release qualities
-Low Rotating Mass (moment of inertia) for quick revs
-Includes CNC machined and anodized flywheel adapter ring
-Blanchard ground floater with multiple straps to reduce noise for streetability
Balancing of you clutch and flywheel together to reduce vibrations is also available
McLeod RST Street Twin Disc 800HP <- CLICK HERE FOR PRICING
McLeod RXT Street Twin Disc 1000HP <- CLICK HERE FOR PRICING
McLeod Street Twin Disc & Flywheel 1200HP <- CLICK HERE FOR PRICING
* Comes with ARP Pressure Plate Bolts
Mcleod Billet Aluminum Lightweight Flywheel 14LBS <- CLICK HERE FOR PRICING
McLeod Billet Steel Flywheel 24LBS <- CLICK HERE FOR PRICING
Don't Forget your ARP Flywheel Bolts Or Your ARP Pressure Plate Bolts <- CLICK HERE FOR PRICING
HINSON Motorsports is a full line distributor of McLeod products. Use the "Search" function on our website to find 1,000's of McLeod products at www.HinsonSuperCars.com.
Former Vendor
Check out our Online Special Pricing on GM Slave Cylinders to help complete your clutch swap. Hinson Motorsports is your one stop shop for all your clutch needs.
GM Slave Cylinder Link
Former Vendor
Former Vendor
Grab yours on our website today and get a Special Price on the Clutch and Flywheel of your choice.
Former Vendor
Check out our A&A Supercharger build thread with install pics of a McLeaod RST. Updates daily.
A&A Supercharge Link w/ McLeod install pics and tons of other install pics CLICK HERE.
2003 Z06 Project Starts with Base Dyno Numbers 100% Stock Z06
Former Vendor
Another shipment in stock and ready to go. Don't hesitate or they will go out the door to someone else.
Former Vendor
More of these found a new home over the weekend. Still have some in stock and ready to ship. Thank you again Corvette Forum for your continued support.
