Help ?? changing differential fluid
I am getting ready to change my differential fluid with GM fluid part # 88862624. I’ve read on the forum you have to do 10 figures 8's after the fluid change. Once I changed the fluid I will have to drive about 5 miles before I can get to an area where I do the figure 8’s safely. Will driving that distance cause any damage to the differential? Thanks
Until you do the figure eights, you may still get any groaning noises that you have now, but no damage will be done. The procedure is recommended so that a customer doesn't pick up his car from the shop, drive out and find that the noises have not gone away...and then complain.
Received 2,051 Likes
St. Jude Donor '13
Also, suggest remove the Fill plug before removing the Drain plug.
There have been a few people who drained the diff and then discovered they couldn't remove the Fill plug to put the new stuff in.
Retired & lovin' it!
So true, so true! You will also find that on the '05, it's a bit difficult to get a hex drive into the drain plug which is directly over the rear spring with very little clearance. (The diff case design change in later years solved this problem). So....you might want to be sure you have the right tool before you start the job. I found a 10mm hex wrench & cut down the short end to about 3/4" & then use a short section of steel pipe on the long end for leverage.
