NGK vs. AC/Delco
NGK vs. AC/Delco
So I decided to upgrade to what I thought would be an upgrade in spark plugs which were the NGK TR5 V-Power plugs from my stock LS3 AC/Delco plugs.
My car has minor boltons: CAI/Headers/Tune/etc...
I ran the AC/Delco plugs about a week and a half ago in 800 DA and saw 0 KR (Knock Ratio) with HP Tuners.
Fast forward to this past Sunday and me putting in the new NGK TR5 plugs. I made 0 changes to the tune, DA was 1900, meaning that the air was fatter and I shouldn't have seen any knock whatsoever. Wound up getting about 6.7 KR through 2nd and 3rd gear. I could only imagine how bad the knock would have been in lower DA.
Anyways,
I'm going to be switching back to AC/Delco plugs, but haven't decided on LS7 plugs or LS9 plugs. I'd like your input and thoughts.
Thanks,
Jason
Anyways,
Thanks,
Jason
Interesting, you did go 2 steps colder than stock with the tr5's so I wonder if that could be the reason (I honestly have no idea)..this is assuming you have an ls3.
I recently swapped from my delco plugs to tr6ix's on mine and got rid of the knock I was seeing in my scans. I can't add any timing but the stock timing table no longer knocks.
I think you have that backwards Dennis. Lets say for example if I run 25 degrees of timing, if the DA is 1000 and I get 5 KR I know I need to take out timing or add fuel.
With that same 25 degrees of timing, if the DA is 0, KR will be much higher than 5 KR because of the denser colder air charge, making the car run more lean.
I have had good luck with the E3 plugs in my Harley - Davidson. I do not have them in my 13 GS but would not hesitate to do so. I believe the part number is 3.54 for the LS3 engine. Probably the same for an LS2. I'm not going to change out my plugs yet since I only have 3k miles on the car, but would try the E3's when it is time.
Plug gap is the same 40 gap.
Harleys make so little hp almost any plug will work. Iridium plugs last a long time but standard plugs make more hp. I use NGK plugs in my *** bikes but AC-Delco plugs in my GM stuff.
Does it matter, they make them to AC-Delco specs. Who makes AC-Delco oil filters?
