ls2 spark plug wires
Old 10-12-2014, 10:02 PM
Elmemo
Elmemo's Avatar
Default ls2 spark plug wires
Hello can anybody recommend a good set of spark plug wires ? I just want to upgrade wires and spark plugs as well my c6 does have all bolt on mods. Thanks for any feed back
Old 10-12-2014, 10:48 PM
MARSC6
MARSC6's Avatar
I use MSD.
Old 10-12-2014, 10:55 PM
Elmemo
Elmemo's Avatar
But I seen that the biggest size is 8.5mm I wanted to try something bigger like 10 mm . Do you know if they make bigger size ?
Old 10-13-2014, 07:56 AM
MARSC6
MARSC6's Avatar
Not that I'm aware of. Is a bigger size really needed?
Old 10-13-2014, 07:58 AM
timd38
timd38's Avatar
Why? they only are about 8" long and don't touch any other wires.
Old 10-13-2014, 11:02 AM
EVRose
EVRose's Avatar
10mm Wires.
Old 10-13-2014, 02:39 PM
cclive
cclive's Avatar
The wires are only a couple of inches long...they are too short to make any difference.
Old 10-13-2014, 02:46 PM
timd38
timd38's Avatar
http://marylandspeed.com/taylor-thun...03-p-1568.html
Old 10-13-2014, 02:47 PM
Elmemo
Elmemo's Avatar
sorry i ment thickness for better performance ? i was looking at some 10mm wires but dont know what brand to go, so i was asking for some suggestions.
Old 10-13-2014, 02:49 PM
Elmemo
Elmemo's Avatar
thanks i decided to go with Taylor wires they been around for a while and trust them. 10.4mm
Old 10-13-2014, 03:10 PM
timd38
timd38's Avatar
I have had MSD, and now have Taylor, no difference, in my opinion.
Old 10-13-2014, 05:20 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
None of them will make a difference. I've had MSD, Taylor, Stock, GMPP, and autozone. Right now I have 6 autozone wires and 2 taylors on the car. This is on a 1100+rwhp car. I would have just kept the stock wires. Only difference is the fitment and color.
Old 10-13-2014, 06:00 PM
cclive
cclive's Avatar
Bigger diameter wires in a fun color look cool, which is a completely legitimate reason to do them...after all, lots of engine mods are bling.
Old 10-13-2014, 07:26 PM
timd38
timd38's Avatar
Mine have the engine builders logo on them.
Old 10-13-2014, 10:20 PM
Elmemo
Elmemo's Avatar
Thanks everybody I decided to go with Taylor wires and ngk iridium spark plugs
Old 10-15-2014, 11:56 AM
ls1121
Support Corvetteforum!
ls1121's Avatar
St. Jude Donor '14-'15
Good choice, they are what I use also. Good quality wire for a good price and they are Made in the U.S.A.
MSD likes their wires too much, and have read a lot about boot separation when changing out the plugs.
Old 10-15-2014, 01:51 PM
cclive
cclive's Avatar
Great looking engine!
Old 01-31-2015, 11:17 AM
vettegator005
vettegator005's Avatar
probably a totally noob question here but how hard is it to install new wires?
Old 01-31-2015, 01:10 PM
cclive
cclive's Avatar
You can see both ends of the wires in the picture above. It is an easy unplugging of each end and re-plugging the new ones. They are very short because each cylinder has its' own coil right above each plug. In my opinion, the biggest reason to get different ones is for looks.
To ls2 spark plug wires
Quick Reply: ls2 spark plug wires
