Cats...Facts or Fiction?
Putting headers (and mid pipes) on this winter...all stock 05 M6 Z51 with an Edlebrock SC. Below are comments I have been seeing here on CF....and I thought this was going to be an easy decision vs. all the things I had to consider putting on an SC vs. NA project last winter.
No CATS = DRONE...that freakin DRONE! My S Type Borlas are great no drone but I could live with a little louder...just not the DRONE vib thing!!!
My SC would melt the high flow cats?
No cats equal...bad smell in cockpit?
My state emission computer will know someone has removed the cats when they plug in (they don't put a sniffer on it anymore, just a plug in)....$10,000 fine?
If CATS they will get plugged within a year from the SC?
If I have DRONE with no-CATS they can add Resonators (whatever those are) then no problem?
My personal experience with cats and supercharging has not been good. My stock cats were destroyed after a year or so. I then went to ARH headers and high flow cats. The cats lasted maybe a few thousand miles before coming apart and plugging up.
I have no issues with drone running with or without the cats with the headers and NPP mufflers. Than again I have a convertible and it may be different on a coupe.
As far as smell without cats, it can be reduced with tuning, and will also depend on the cam specs. On my car I have got it to where there is no real noticeable smell, other than when I start it in my garage.
They have emission testing in Waukesha county. Today you may get by without cats as log as you don't have any codes.The place that does my emission testing tells me that a visual inspection is coming, so you may have to have some type of cat.
With a proper tune, no cats will pass the OBDII inspection part of the test. However, if they visually check (like they are suppose to), fail. Most inspection places deal with normal cars and don't usually bother with the visual.
Tim I think if it didn't pass you are right I'd have to put them on then as part of the fix.
So all of the performance guys say...no cats you'd be nuts to not get the max out of your mods...want to see my shocked face! My tuner is pretty sharp so my guess is that we could get it right if their was a smell issue. He described what resonators are and what they look like if the DRONE was present but that sounds like some dick'n around with a little back and forth to add those.
just asked.. he says stock V's and ZL1 are good to maybe 500 wheel MAX.. ZR1's good til about 575 wheel.. he's built more than 20 V's and at any given time has multiple ZL1's in there has also built dozens of C6 and Z06's and probably 10 ZR1's hundreds of TBSS's with everything from turbos to whipple, procharger, maggie, Kenne bell etc etc. so i believe what he is saying. i've seen it myself. alot of it has to be very conservative tuning.
guess they're using stronger cats? But when you supercharge a regular NA car the cats are not handling it?
Supercharged 05' here and my aftermarkets cats "honey cone" clogged and melted. I gutted out my cats so it still looks like there on the car for a visual inspection. I have them running to Borla touring mufflers. My car is tuned very well. I have more exhaust smell at an idle from my truck. I get a little exhaust smell while driving from time to time. Nothing compared to some DD cars running on the streets.
