engine ignition
engine ignition
Hey guys,
I have a 2007 c6 and im facing a problem with turning off the engine.
Whenever i press the off button the gauges goes all off except the engine it keeps running for 5 to 10 seconds and still the throttle response then it goes off.
the start is ok its pretty much good.
recently battry was changed.
yet the voltage drops to 12.5 and when i push the throttle it goes up again to 13.4.
im not sure if this is somthing to do with the alternator or not or its the ignition switch, although the start is perfect.
