Installing Kooks Headers on Dry Sump GS..Any advice?
I'm going to be installing some Kooks 1 7/8 headers & catted-x on my 2011 Grand Sport in my drive way on some jack stands. Can anyone offer any useful advice before I start? Looks like I'll be changing the plugs and I'll have to order some new msd wires and something to protect them from the additional heat. I need to pick up that tool to remove the o2 sensors, but I believe I have everything else I'd need. I just wasn't sure if there was any additional work with the dry sump as compared to the standard wet sump.
Someone posted a pic by pic write up on how to install headers on a grand sport dry sump out here, but I can't find it now. It was with PDFAT headers I believe, so it would be the same for you.
I had LG Super Pros installed by a local shop, because they did not charge any more to install them. It took them around 4 hours, and they were meticulous when doing it, and they did it on the drive on ramps.
They only had the vette about 2 feet off the ground, and the height worked fine.
edit - Here's one DIY thread - https://www.corvetteforum.com/forums...-dry-sump.html
I installed some on my dry sump GS earlier this year and the oil lines came very close to the headers, so I wrapped them in heat insulating tape at that spot. I also used it on the clutch line and some of the wires, and I think I might have used some on the brake and fuel lines too. Basically I just taped up anything I thought looked too close to them for my tastes. Might have been unnecessary, but I gave me peace of mind.
