Help with an electrical issue
Hey guys, so I found the C6 M6 I wanted and the headlight assembly has a weird hole in the bottom of it that has a clear bulb sticking through it facing up, that illuminates with the headlights like a parking light. I've seen headlight assemblies for sale like this on ebay and don't really understand it. I'm guessing it's not oem. Anyone know what that is for or why they're like that?
Anyway, the parking lights (the orange ones) won't turn on at all, and neither will the fog lights. I can hear the actuator activating the fog lights, but nothing turns on. Everything out back works, it's just the front. The dealer said they will look at it and find the problem, but I really don't have much faith in them and was hoping to get some insight from you folks so I can maybe steer them in the right direction. Obviously check simple things first like if they're connected, fuses, etc. Just curious on your thoughts and if it had anything to do with that weird headlight assembly with the light in the bottom of it.
Any help much appreciated!
My opinion is that one of the previous owner botched up trying to mod the lights.
My opinion is that if you can get the price of the car reduced by the cost to put it back to stock, consider it otherwise walk. The headlights are very expensive, even if you buy them from forum member RLSebring. The harness may also be messed up, so I would include the cost of replacement harnesses. I would ask for a couple maybe 3 grand off the price of the car and if you are handy you can probably replace all of that for $1500 (used) yourself. There are many threads on the "easier" way to replace the headlights.
But examine the car very carefully for what else they screwed up!
If you already bought the car, well lesson learned and welcome to the Corvette club. Contact RLSebring and he should be able to set you up with everything you need to put it back the way it should be.
Thanks. Already bought it with the condition that this would be fixed as part of the deal. The price was reduced quite a bit as well to reflect the problem. We shall see if they follow through. Here's the headlights that are on the car (different color) with the extra "marker light" as they call it. Advertised as "European style" whatever that is.
http://www.ebay.com/itm/05-13-Corvette-C6-Headlight-Assemblies-CARLISLE-BLUE-Pair-NEW-EUROPEAN-/111358452325?pt=Motors_Car_Truck_Parts_Accessories&hash=item19ed7b2265&vxp=mtr
I should mention that the orange lights work perfect when locking the doors, using the blinker, etc. Hazards work fine. And like I said, I can hear the actuator turning on with the fog lights also. I'm wondering if it might be a ground issue?? The fog light indicator light turn on in the dash.
European lights have a "town bulb" in them that illuminates the light so that others can see you without putting out light for you to see out. In european cities, the thinking is that visibility is the reason for headlights.
Not more complex...they look much like a D-cell flashlight bulb and are only meant to provide visibility to the front of the car. The US has always had very different headlight standards from Europe. We have caught up quite a bit as our headlights 20 years ago were considered simply inadequate in Europe. Here's a pic of a 250SL Mercedes with European and US lights:
Here's a pic of a Porsche headlight unit. The lense at the top is the high beam, the blue bulb in the middle in the big reflector is the low beam and then off to the right of the blue bulb is the "city" bulb. Apparently many of these are now LEDs:
GM Euro spec headlamp
[QUOTE=BruiSSer;1588132303]Thanks guys. It's all fixed. Something wasn't plugged in and a dies was out. Back to normal now.[ works fine on our cars as long as you get the extra wiring harness that goes with it
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I completely forgot about the Euro, around-city bulbs---I think the '66 Beetle used to have a small bulb in the headlight that was the parking or around town light. IIRC, Euro cars used to also have a single tail and sidemarker light that you could leave on, either right or left side, if parked on the street. Long ago, in Paris, many cars parked halfway up on the sidewalk and left the outside lights on.
Just as a caution, OP, I'd watch carefully to see that your battery level doesn't go down in case there is some other kind of wiring short. Just bein' a little over-cautious, y'know....
