c6z06 trans + diff fit in 2005 c6?
Does the 2007 z06 trans and dif fit in 2005 my m6 c6?
Or do i need the z06 cradle?
Does my electrical fit the trans and diff?
does the driveshaft fit?
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Other than re-wiring the reverse sensor wires/re-routing fluid lines, its a direct bolt in. Your torque tube, diff mounts and cradle will work. We have done this conversion many times.
I did this in my 05 auto car.transmission output shaft had to changed to 30 spline and needed adapter plate for transmission to 08 Z06 differential.everything other than that was plug and play including differential cooler.cradle holes holes had to be slotted 1/4"
