mantic or monster twin disc clutch
Hoping to get some feedback and opinions from members with experience with either of these clutches. I'm considering either a mantic 9000 twin disc clutch or monster twin disc clutch for my 2013 grand sport 6 spd with A&A s/c (630 rwhp). Both will support up to 1000 hp/tq and boast good street manners compared to stock. There are many opinions on the Web about mantic (mostly good) but it's hard to find opinions on monster. Pros/cons of each? Which one is most like stock feel for stop and go traffic? Chime in with your thoughts!
There was some chatter right after the install but that is almost gone now as I'm getting a little mileage on it.
McLeod RST or RXT if you plan on drag racing.
Pick a friction material for your use. Organic will have maximum smoothness but will fail under high heat. Ceramic isn't quite as smooth, but will hold heat.
I do hpde road courses once per month or bi monthly mainly. .. I drag race maybe once per year
Former Vendor
Here is a recent review of the LT1-S twin disc
https://www.corvetteforum.com/forums...t-in-here.html
Also we recently put a standard weight LT1-S in a 5 Gen Camaro and posted the dyno numbers here.
http://www.camaro5.com/forums/showth...monster+clutch
Well I good street manners and I drag race. I drove the C7 and loved how soft the clutch effort was. I want my C6 to have that soft of a clutch so I can slip it better off the line. I tried slipping the stock clutch and glazed it over.
Former Vendor
<<<@!1!@>>>
The LT1-S is based on the C7 Twin disc, it has fantastic pedal feel and street manners.
Here is a GTO Slipping the LT1-S to get off the line.
<<<@!1!@>>>
https://www.youtube.com/watch?v=BNg7j-w2iJo
Former Vendor
Would your stage2 single disc be adequate for a 550 whp LS2 with little or no track time?
If you plan on staying in that power range the LT1-S twin disc is perfect for want you want, it's rated at 700/700RW and drives exactly like stock.
So how much drivability and quietness would I be sacrificing by going with your next level twin disc that will handle 1000hp/tq?
Former Vendor
Had my mantic 9000k now for ~6k miles, no issues. Drives great. Making between 900-1100rwhp in that time. Best clutch I've owned.
