Axle nut solution - Nord lock with part #s
Instead of the usual Loctite 262 and new set axle nuts:
Nordlock makes an M27 washer that is 1.9" wide - the nordlock part # is NP27SP or 1551. Grainger sells them for 12.89 apiece. The Part# on Grainger is 12W476 http://www.grainger.com/product/NORD...-Washer-12W476
Note: Even though the axle is an m27, the washer is a bit larger. To get it centered on the axle, you can tighten the axle nut until it is just barely holding the washer against the hub, then used a flathead screwdriver to center it with the nut before tightening down all the way.
Also mark the nuts to note any future movement.
I hope this helps some folks out!
Another alternative, cheaper, online with tannerbolt:
Nord-Lock Steel Wedge Lock Washers, Bolt Size: M27, OD: 1.91", Enlarge OD, Thru Hard Steel w/ Zinc Delta Protekt Coat, NORD NL27-SP/1551 - 1 Pairs/PK
Nord-Lock Steel Wedge Lock Washers, Bolt Size: M27, Outer Diameter: 1.91", Enlarged Outer Diameter, Through Hardened Steel with Zinc Flake Delta Protekt® Coating, NORD NL27-SP/ ...
See more details at Tanner »
$6.73
+$6.50 shipping. No tax
Tanner
That price is half of Grainger's for Zinc coated carbon steel. Or $27 + change to get the 316SS version, thats what I use.
Where I live in Oahu, Grainger will charge me higher shipping + tax.
Tannerbolt only charge me USPS Flate Rate Box and no tax.
HTH someone!
$6.73
Tanner
HTH someone!
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Good solutions, but expensive! Not complaining tho. Is there no way (or not enough thread) to use two axle nuts?
also nordlocking is supposed to be more reliable than the double nut techique. Here is a video testing various methods of fastener use:
EDIT:
forgot to note that nordlocks are reuseable
St. Jude Donor '15
"In honor of jpee"
Ah! That's good info. Thanks!
