525-550 HP from naturally aspirated LS3?
This is a question for the experts who have been there, done that. I have a very low mileage 2011 Z16 coupe. Wixom built forged crank LS3, M6, NPP, dry sump, coolers, etc.
I want to add 100+ hp, without significantly affecting driveability and reliability. I know the usual headers, cold air, t-stat, tune gig applies, but I wouldn't expect those mods to get me where I'd like to be.
I also don't want a blower on a 10.7:1 motor, and I'm not a NOx guy.
So, a cam, some headwork, and what else??
How much gain in a good aftermarket exhaust compared to the NPP?
What should I expect to spend on just the parts to get this done?
Thanks in advance,
Garry
Thanks in advance,
Garry
525 hp in a naturally aspirated LS3?
TFS 255 professionally ported heads
G6x3 Cam with 112 to 114 Lobe separation. (pretty choppy.....but you're have a M6)
Fast 102 ported intake
Stock (Or Any) Exhaust With Cutouts
Hi Flow...or eliminate cats
Good Tune
Higher ratio rear (3:90s?).
presto......you're over 500rwhp with a streetable vette.
If you do the work yourself....your looking at 4000+ dollars in parts. Figure in another 2-3k in labor for a good shop to do it. (Blower might be a smidgen cheaper here) :-0
Good Tune
Last edited by JimiHendrix; 10-31-2014 at 12:21 PM. Reason: meant TFS 255 heads...not smallish 225 heads
TF 225 professionally ported heads
Good Tune
Good Tune
Gary
I have a 13 GS. I have American racing headers, Cam, tune, Brian tooley spring kit n push rods and c5 chain. The car is now pushing 540hp
Btw. I'll be moving to Az in December. I'm heading to Az next week to purchase a home in Goodyear or Gilbert.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Garry
Stock displacement....it's going to effect driveablity, at least it won't drive like a stock car I'll put it that way.
I think the most we have done on a stock LS3 short block is 539rwhp on pump gas (ported LS3 heads, FAST 102/102, G6X3, our 1 7/8 headers, full 3" exhaust, underdrive pulley...)
Most on a built engine, 100 octane and stock displacement was 569rwhp.....ported LS3's, FAST intake, 102tb, G6X3...
Guys, he's not asking for 525-550rwhp, just flywheel horsepower. That's baby stuff with killer heads and a stealth cam. All you need is 450-475rwhp. With the TFS heads, milled for higher compression and an RCR modified LS3 intake, I promise, you can make 475rwhp+ with a cam with -10 degrees of overlap at .050". That would pass smog in any state, be wife/GF/client approved and return excellent fuel economy. Without the good heads and intake, you'll need a much dirtier, choppier cam to make 475rwhp.
Received 2,061 Likes
So what's the consensus of rwhp needed to run 125-126 MPH in the 1/4? Just curious what other people think that takes.
Thanks for all the replies. I should have been more clear, I'm not expecting 525 at the rear wheels. I'd be happy with 450-470 at the wheels.
I do not want to change pistons, and I do not want to buy new heads. I was hoping to simply clean up the stock heads. This means no significant decrease in compression ratio, which means a blower is a bit of a waste. If I was going to heads with larger combustion chambers or changing pistons, a blower would make much more sense. All of that however is beyond the budget.
I'm hoping to acheive 450 rwhp without spending more than 4K on parts. Possible?? I will do the work myself.
Thanks again for the advice and insight!
Garry
Garry
I was right at 500rwhp with Kooks headers, Airaid, and a Spinmonster cam thru a base M6. Numbers you are looking for are easily surpassed with bolt ons and a camshaft.
I was kinda thinking about those same numbers, but I haven't done a legitimate dyno pull since a 381 rwhp one 5 years and several mods ago. Although I have run quite a few 125 and 126's with just bolt-ons, adding a cam should put the OP well over his goal. He could hit the lower end of the goal with just the right bolt-ons and a good tune.
Former Vendor
Garry
Garry
If that's the case, a set of long tube 1 3/4" headers, cold air, underdrive and something like our X1 cam would do that. Give you a nice little lope at idle and drive almost like stock.
That was from a 2008 M6 car.....the baseline graph already had our 1 3/4" headers on it and stock NPP exhaust.
Premium Supporting Vendor
Garry I dont think those power numbers are a problem at all. Infact I think you can add 100 hp easily for very reasonable $$$.
If you do a TSP cam package & we do your heads on cnc exchange you'd be well under $2,000!!
CNC ported heads add 25-30rwhp depending on milling for $900ish
http://www.texas-speed.com/p-1388-pr...d-porting.aspx
Cam package will add the rest of the power or more depending on size for $700ish
http://www.texas-speed.com/p-1158-te...pring-kit.aspx
Gaskets & bolts add another $150ish..
If you want headers & x pipe your talking another $800ish
http://www.texas-speed.com/p-3198-te...kage-w-02.aspx
Garry
Garry
I'm sure a mild cam and FAST intake would probably get what you are asking for, along with headers.
Here's another result with intake, custom road race cam, LT headers, NPP, tune and high flow cat's
https://www.corvetteforum.com/forums...post1587307920
