tested klotz octane booster
We used the same methods that the oil refineries use to release product. Started with a 91.7 road octane w/10% ethanol. Added 1 ounce per gallon ratio and ended up with a 92.7 road octane. So it's a little more convenient than keeping 100 octane around to mix and it's a little cheaper if you buy 1 gallon at a time. But this stuff eats through paint so you have to be careful.
Supporting Vendor
It costs around $80 a quart but only requires one ounce per 5-6 gallons of gas (depending on your compression ratio) and will bump your octane up by 9 points according to the manufacturer's claims. While I have no idea if that part is exactly true or not, I can attest to the fact the stuff works as I haven't needed to buy 100 octane race gas at all after I started using it several months ago.
To be honest I've never been a fan of octane boosters in the form of an additive but changed my mind after Dave Myers from Yank Performance suggested I try it. What I did was go to a Test and Tune in Sacramento running 91 octane and 2 ounces of the stuff. To be safe I pulled out 10 degrees of timing and then started making passes.
After each pass I would check my scan and as long as I wasn't seeing any engine knock I would add back in 2 degrees of timing. By the time I was done I was actually running a little more timing than I had ever run with a 95 octane blend (91 mixed 50/50 with 100 octane) and the car ran great.
The stuff also has the added benefit of increasing upper cylinder lubricity but I only use it for the octane bump.
Let me know if you want to stop by and try some out one day as I keep some extra with me at the house.
Not sure how much that stuff costs per ounce but you might wanna try something called Aces IV.
Lots of information on his site.
He says I can run it without changing the tune. It will richen up the a/f ratio some with no harm.
Some crazy claims so I started a thread looking for more reviews.
Your review gives it some legs, I respect your thoughts.
Supporting Vendor
I am not sure you guys know what an octane booster's claim of one point means. Do some research and you will find that when a bottle of octane booster reads "raises 20 gallon tank 1 point" Well, what they are saying is that you have a 20 gallon tank of 87 octane it will raise your octane level to 87.1 octane. Yes, one point, not one full octane like 88. I will probably get beat up over this but it's true.
Supporting Vendor
As I stated earlier, while I don't know how much the octane actually gets bumped I do know that I'm running more timing with the additive than I used to running a 95.5 blend from the pump.
As such, I would say that it's getting raised to at least 97, possibly a little more.
The Aces IV is interesting. Poking around I found a couple R6 guys claiming they can run a 100 octane tune on the Aces IV. Some of the Dodge guys claim it works, but almost none of them had data; just SOTP data. If one ounce per fill up can allow for 96 Octane timing to run on 93 pump gas, that's a pretty cheap way to pick up performance.
Any knowledge of whether it is cat converter friendly on a long term basis?
Supporting Vendor
Never had a problem with the catalytic convertor, changed spark plugs every couple of months. Only way you could tell I was using Torco was the light reddish orange deposits on the tail pipe.
Believe the attached Torco chart, it is correct. Be advised that 100 octane acts different with different air density. 100 octane may be enough at cool temps and high density but high temps and low density the engine can still knock, even with 100 octane.
You can always use the Torco unleaded race fuel concentrate if you are worried about O2 sensors. I use it for a turbo 1000cc snowmobile at 18# of boost with no problems with the engine or sensor.
Thanks, maybe i will try the acesIV because it sounds like it would be more convenient. My car has bumped compression and is tuned on 91, but i just like to have some cushion. It just seems crazy that 1/6 of an ounce per gallon will raise 91 octane to over 95. With torco it takes 1.5 oz from that chart. The klotz is $50 a gallon and 1oz/gallon for 1 octane.
There is also a huge difference in the price per quart between the two. Torco at less than$20 per quart or Aces IV at $80 per quart. Not discounting one or the other but can say the costs are close.
That 1.6 oz of Torco would be 1/20 of the 32 0z can. The can is about $20.00 for 32oz so $10.00 for 16 oz. You're looking at about a Dollar for 1.6 oz to get 100 octane for 1 gallon.
Klotz at 1oz for 1 point per gal from 91 octane would take 9oz to get to 100 octane. $50 a gallon = 2.56oz per dollar so 9oz would be $3.51.
It works in what way? Did you notice any improvements at the track or on the dyno? Did it eliminate any KR you may have been experiencing? Was the smoother running engine the only difference you noticed? What mods do you have, if you don't mind me asking?
