VATS security light on when car is running
Old 11-20-2014, 02:50 PM
eugenecruz1974
4th Gear
eugenecruz1974's Avatar
Default VATS security light on when car is running
Hello forum, my name is Eugene i have a 2002 c5 and after it came back from a dyno tune security light is on. i bought a brand new original key thing it might be the key no luck, car has a new batterie. i tried the resistor to bypass the VATS no luck either light does not turn off while the is running. i have no problems starting it it works fine even with the light on. any sugestion of what could it be? maybe a a Bad BCM?
Old 11-20-2014, 02:54 PM
eugenecruz1974
4th Gear
Hello forum, my name is Eugene i have a 2002 c5 and after it came back from a dyno tune secutrity light is on. i bought a brand new original key thing it might be the key no luck, car has a new batterie. i tried the resistor to bypass the VATS no luck either light does not turn off while the is running. i have no problems starting it it works fine even with the light on. any sugestion of what could it be? maybe a a Bad BCM?
Quick Reply: VATS security light on when car is running
