2014 Katech Holiday Sale - UP TO 50% OFF! Now through 12/31/14
Premium Supporting Vendor
We are having a sale now through 12/31/14 on the following products. Use the coupon codes below to get the discount. If a coupon code is not used the order will not be discounted and we can't reverse that, so make sure you use the coupon code. Only one coupon code is allowed per order. If you want to purchase multiple items that are on sale please place multiple orders.
The following C6 aero parts are 15% off
Coupon code: C6AERO14
Base C6 splitter, CF http://store.katechengines.com/carbo...tter-p281.aspx
Base C6 splitter, FG http://store.katechengines.com/fiber...tter-p282.aspx
Base C6 side skirts, CF http://store.katechengines.com/carbo...irts-p284.aspx
Base C6 side skirts, FG http://store.katechengines.com/fiber...irts-p285.aspx
Z06/GS/ZR1 splitter, CF http://store.katechengines.com/carbo...tter-p193.aspx
Z06/GS/ZR1 splitter, FG http://store.katechengines.com/fiber...tter-p215.aspx
Z06/GS/ZR1 splitter/undertray/brake ducts, CF http://store.katechengines.com/carbo...-kit-p212.aspx
Z06/GS/ZR1 splitter/undertray/brake ducts, FG http://store.katechengines.com/fiber...-kit-p225.aspx
Z06/GS/ZR1 side skirts, CF http://store.katechengines.com/carbo...irts-p189.aspx
Z06/ GS/ZR1 side skirts, FG http://store.katechengines.com/fiber...irts-p207.aspx
C6 (all) spoiler, CF http://store.katechengines.com/c6-ca...iler-p182.aspx
C6 (all) spoiler, CF pimered http://store.katechengines.com/c6-pa...iler-p317.aspx
Z06/GS/ZR1 front fascia reinforcement http://store.katechengines.com/katec...tter-p198.aspx
Katech supercharger heat exchangers are 20% off
Coupon code: HX14
Katech ZR1 heat exchanger http://store.katechengines.com/corve...nger-p195.aspx
Katech ZL1 heat exchanger http://store.katechengines.com/camar...nger-p388.aspx
Katech CTS-V heat exchanger http://store.katechengines.com/cadil...nger-p267.aspx
Katech valve covers are getting a revision to the oil cap and we are selling all remaining stock of the previous design at 30% off and giving free logo inserts. Both items must be added to the cart for the coupon to work. This sale is WHILE SUPPLIES LAST. Placing an order does not guarantee availability and you will be notified if they have been sold out.
Coupon code: VC14
Katech cast aluminum valve covers, slotted, dry sump http://store.katechengines.com/cast-...overs-p15.aspx
Katech cast aluminum valve covers, slotted, wet sump http://store.katechengines.com/cast-...overs-p15.aspx
Katech Performance logo insert http://store.katechengines.com/valve...-logo-p55.aspx
Also recommended:
http://store.katechengines.com/coil-...n-kit-p13.aspx
http://store.katechengines.com/custo...overs-p52.aspx
http://store.katechengines.com/msd-s...wires-p41.aspx
http://store.katechengines.com/spark...ator-p291.aspx
Buy a Katech camshaft (below) and get 50% off titanium valve spring retainers.
Coupon code: RETAINERS14
K501 cam http://store.katechengines.com/k501-camshaft-p389.aspx
Torquer LS3 cam http://store.katechengines.com/torqu...haft-p221.aspx
Torquer LS7 110 cam http://store.katechengines.com/torqu...shaft-p11.aspx
Torquer LS7 116 cam http://store.katechengines.com/torqu...haft-p223.aspx
Titanium retainers http://store.katechengines.com/titan...tainer-p9.aspx
Also recommended:
http://store.katechengines.com/sprin...ides-p374.aspx (if using OEM guides)
http://store.katechengines.com/sprin...ides-p322.aspx (if using bronze guides)
http://store.katechengines.com/psi-h...prings-p8.aspx
http://store.katechengines.com/intak...seal-p324.aspx
http://store.katechengines.com/exhau...seal-p323.aspx
http://store.katechengines.com/c5-r-...chain-p30.aspx
The following Katech billet belt tensioners are 25% off.
KAT-A4425 (all colors) for cars use coupon code: TENSIONER14 http://store.katechengines.com/bille...sioner-p2.aspx
KAT-A4426-BLK for trucks use coupon code: TTENSIONER14 http://store.katechengines.com/bille...sioner-p4.aspx
Buy a FAST LS7 intake and get Katech billet fuel rails 25% off.
Coupon code: FAST14
FAST LSXR 102mm intake http://store.katechengines.com/lsxr-...fold-p127.aspx
Katech billet fuel rails http://store.katechengines.com/bille...ails-p287.aspx
Also recommended:
http://store.katechengines.com/paint...lack-p379.aspx
http://store.katechengines.com/bille...-kit-p270.aspx
http://store.katechengines.com/nick-...body-p326.aspx
Katech C7 carbon fiber engine covers are 25% off
Coupon code: C7COVERS14
Center engine cover, CF http://store.katechengines.com/carbo...nter-p406.aspx
Center engine cover (fiberglass), red http://store.katechengines.com/gelco...nter-p429.aspx
Side engine covers, CF http://store.katechengines.com/carbo...ides-p410.aspx
Coil covers, CF, dry sump http://store.katechengines.com/carbo...vers-p409.aspx
Coil covers, CF, wet sump http://store.katechengines.com/carbo...vers-p409.aspx
Coupon code: HX14
Coupon code: VC14
Also recommended:
Also recommended:
Coupon code: FAST14
Also recommended:
One set of slotted, wet sump valve covers available at this price. Everything else is sold out.
