issue with drivers door window
so when you open the door the window is supposed to drop down to clear the targa roof, which mine does.. However if I leave the door open the window will go back up which prevents me from closing the door without the window hitting the targa roof. It also wont let me roll any windows up or down while the door is open with the ignition on.
Any clues?
Any clues?
For starters, try re-indexing the windows.
If that does not work, disconnect the battery for a few mins to to reset the system, then re-index the windows afterwards.
When you unplug the pads, be careful to not let the wiring harness and plug fall back inside the door. Retain it in some way.
