Long awaited smog scoop
I underwent my first inspection for the 2008 C6. I returned it back to stock mostly. I previously had full bolt on's.
Now I have the Z06 manifolds and "H" pipe along with a tune and a ring and pinion change in the differential, 4:10's.
There was a lot of speculation early on with the news of the OBD scan with the elimination of the tailpipe sniffer. This was maybe 3 years back and finally in August, after some delay, California implemented the new law.
Talk of the tune showing up and I also read talk of the gear change showing up too on their test software. Both possibly would indicate a fail condition. The Z06 swap while oem is not technically legal but nevertheless it passed the visual as did the car.
I hope this will elevated some other's fears. I have not read much about this issue in the past year or so.
It fully takes effect in 2015. There was a grace period for the shops to get up to speed with the software from the August go ahead.
I am one happy camper ...
Posted up in the general section and added it here.
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
Missed it in Gen section, Booms! Glad to see it here. BTW, what is your car putting out with the tune and the Z's exhaust system on a LS3?
But remember I have the 4:10 gearing an as I understand it is worth about an additional 10 hp. at this power level.
I was 400 400 with tune only all else stock. Most report 10-12 rwhp with the Z06 stuff so this is about in the same ballpark. The torque took the hit with little gains over the tune only numbers.
The gear change messes up the calculating.
I have no dyno numbers with just the 4:10's. They were added after the vararam and AR headers.
With the 4:10's and the headers the car really woke up.
St. Jude Donor '15
"In honor of jpee"
Thanks for the info, Dave.
I didnt think they could see everything down to that level with a scanner. I thought they could see if the computer had been flashed within a few hundred miles. Guess Ill find out later this year.
The tech thought that the new laws were going to miss stuff too.
Ya I made sure to put that sticker in the engine bay from the fast. Inspector tried to ding me when I moved to CA with the CAI on my truck because one number had a scratch on it.
St. Jude Donor '13-'14-'15
Here in Calif where I am---The new smog rules say that they simply check to make sure all the "readiness tests" are completed --and 2nd there are NO DTC's or codes--and 3rd visually no smog equip has been removed (cats -- air pump--EGR etc)
That is for any car 2002 or newer---
Good news is that any tuner can permanently set ALL your readiness tests to "ready " permanently--and remove any codes permanently---
The question comes up if a smog shop can tell if alterations have been made to your ECM to alter these settings----The simple answer is NO----Even the dealer can't tell IF your ECM has been altered----
NOW in 2014 GM and others have now encrypted their tunes and there IS a possibility that someone can tell via your ECM's "Checksums" that it's been altered
But so far because new cars in Calif don't require a smog for 4 years we won't know for sure IF that is indeed correct or just a scare tactic for 4 years
But for any car 2013 and older I know I can make any car pass smog if need be by tricking the ECM and No one will know----but me and the owner---------------
Here we go with the Checksums again...
This is what the speculation was for me 4 years ago.
Hence why I posted.
This includes any aftermarket headers that do NOT have a CARB sticker
Same goes for the air intake system---it is considered smog equipt
so again any aftermarket replacement must have a CARB sticker
Sorry for the confusion----
Basically after Jan 1st in Calif---any car 2002 or newer will NOT be run on the sniffer or rollers to check NOX or HC's---all they will look at is:
1 . Visually no smog equip has been altered and if so that part has a CARB sticker
2. There are NO DTC's
3. All the readiness tests read "ready"
To make it clearer I said that---- 3rd VISUALLY no smog equipt has been altered-- The exhaust system is part of the smog system
