Instructions on zr1 splitter install on base c6
3rd Gear
I just purchased (pre painted) a ZR1 Splitter for my base c6 from RPI. looking for any instructions on how to best install. I have no lift. Do I need rivet gun etc. No plans to add brace. Can anyone point me to another thread addressing this?
I lifted one side at the front jacking point and lined up the edge of the splitter with the fender. Put 2 screws on that end then lifted the other side and did the same thing. That way its lined up on the ends correctly then lift the center up and put a screw there. I used a box under it to support one end while working on the other. Then finish off all the way around. I used a 1/8" drill bit. Took about 45 minutes.
