Are Camaro ZL1 Heads compatible with a C6 LS3?
Are Camaro ZL1 Heads compatible with a C6 LS3? Do they flow better then ls3 heads? I have a 2012 Procharged LS3 Vette in the shop for a 416 build.
The LSA heads work great. They require a minimum of a 4" bore so they are fine on the LS3. They are made of a better alloy, have a slightly thicker deck, the rocker bosses are gusseted, and the combustion chambers are smoother than anything else ive seen come from the factory.
Its just a shame that they jacked the prices on them. Two years ago you could buy the bare castings for $350 a set. Now they want almost $800 for them. Guess they realized they had something the aftermarket would want.
My buddy and I hand ported a set and filled them with Ferrea Inconel exhaust / Hollow stem intakes and BTR springs and slapped them on his 408/YSI engine, they work great so far... Just finished their second year making just under 1000whp.
I would recommend the LSA's to anyone looking for a strong budget head.
