Kooks LT, CAI and Tune 419 HP and 430 TQ
Alright my first set of mods are done.
I did a kooks long tube headers 1-7/8" Catted X pipe and NPP Muffler set up
Halltech CAI and MGW shifter
Installed and tuned By gearheads performance in Arlington.
419 RWHP and 430 RWTQ
More impressive than the top end numbers, Is the amount of additional torque he was able to build in, in the lower RPM range.
I just thought I had traction problems before
Travis (the tuner) told me the car was pulling 4-5 deg of timing from about 4800 RPM to redline.
He said I could have bad gas. He wants me to run this tank out completely and refill with a quality premium 93 Oct. then bring it back and do another pull. The gas in there was 93 Oct that had been in there for about a month
He said that the pulled timing was costing me 4-8 HP on the big end
The runs were done at about 50 degrees and it made a little more power each run. I don't think heat soak was the issue, but I don't know that for sure
I will do a thermostat when I do the cam
Thanks for the idea, I will ask Travis
Fuel
I've been told by corvette specialist tech. From a chev dealer to ALWAYS use premium grade fuel vendors...shell, Mobil texaco etc...and of course 93 octane.( I also use StaBil additive because of the ethinol)
I will get her re-fueled and have Travis make another pass
