F55 quarter mile racing question
What would the ideal setting be for quarter mile racing ? Sport or touring. I've ran my A6 grand sport a handful
Of times and have completely overlooked this setting so I'm curious to know if theirs a
Diffrence between both at the drag strip . I tried to do some research but could only find diffrences in turns and regular driving
but I would really like for someone with more experience with these suspension to weigh in. We start racing in the next couple of weeks in Texas
Received 2,060 Likes
So far I've gotten a 1.49 with 2.73s , yank 3600 , cam and bolt ons, that was on stalling at 2k , it dead hooked on 28 hoosier slicks at 17psi , same set up on a 100 Shot got me a 1.38 also stalling at 2k , when I stalled it to 2500 it broke the tries loose off the line , this was on sport mode tho, if tour is better then imma go back and try it with less psi and hope to improve my 60 ft
That pic and this one were both in the 1.60 range and you can see 40-50' out it still hasn't settled down completely. Now I'm running 60' times in the 1.48-1.50 range and well into 2nd gear before the front drops much.
Yea usually I raise my car all
Around for track nights, that for sure I've noticed makes a diffrence , just finished installing my progressive nitrous controller so
We good
To go
We good
To go
Inconclusive results with only 2 passes. Especially when the second one beat your 60' PB. Since you got rained out, I'd guess the DA dropped between passes too. Keep records of DA on each pass and use the Dragtimes calculator to record adjusted times. For temps, Hum, and BP, I prefer to use weatherunderground.com (find the closest station to the track). the use Google Earth for mid-track elevation. The Dragtimes weather and track info has several errors and only uses the closest major airport hourly reports, but their calculator works just fine.
Imma see how it works with the nitrous , I'm starting to think that the 28 might be too much tire for motor now that we getting the launch dialed in, forgot to mention that the psi was dropped to 14 for these 2 runs compared to 17 in my previous best , that has to be a big factor
