Heat shields
Old 02-27-2015, 03:54 PM
Jack Forbes
Jack Forbes's Avatar
Default Heat shields
Does vararam make a heat shield for ls2 base 2006 to cover void from radiator toward motor
Old 02-27-2015, 03:58 PM
timd38
timd38's Avatar
Call them
VARARAM INDUSTRIES
1420 Preston St. Suite E
Pasadena, TX 77503
Toll free: 1-866-507-2648
Telephone: 1-713-477-8100
FAX: 1713-472-1016
Old 02-28-2015, 03:08 AM
Dano523
Dano523's Avatar
Received 3,001 Likes on 2,166 Posts
Better question is why?
Unless the Maf with AIT sensor is moved to under the heat shield too, then kind of pointless since the intake is still pulling air from the front outside of the car, and not the engine bay.
Old 02-28-2015, 10:24 AM
dentalfloss
dentalfloss's Avatar
I thought the Maf with AIT measured air temp/air density in side the air intake tube not outside. Could you give me some 101 on that? Thank you
Old 02-28-2015, 05:23 PM
dentalfloss
I have an LS2 and have yet to find a heat shield as you described.
Old 02-28-2015, 08:39 PM
Dano523
Dano523's Avatar
It is, but if you are staging long enough with low flow through the intake/MAF and the engine bay cocking instead, then the engine bay heat can transfer to the MAF/AIT sensor. The run will push enough air through the MAF to cool it back down so timing is not still be pulled, but not before the timing was pulled by the ECM to begin with instead.
This is why some CAI manufacturers have moved the MAF forward under the heat shield instead, like the Halltech SuperBee MF103.
Old 02-28-2015, 08:58 PM
timd38
timd38's Avatar
Halltech has one.
http://www.halltechsystems.com/Hallt...om-p/v2026.htm
Old 03-01-2015, 08:50 AM
dentalfloss
Thank you Dano 523 and timd38. From what I see from Halltech, The heat shield comes with the package for $585. plus tuning could be a cost of $800.-$1000. I do not see the heat shield being sold separate. Maybe I'm wrong. I will give them a call.
Old 03-01-2015, 03:41 PM
martysauto
martysauto's Avatar
St. Jude Donor '14
I think this is what your looking for
http://www.corvettemods.com/C6-Corve...d_p_10021.html
Old 03-02-2015, 02:46 PM
dentalfloss
I just telephoned the above link, Corvette Mods and spoke to Mandy and was told that it does not fit an LS2 2006-2007 Base model. So far I have yet to find a CAI shroud for a LS2 base model anywhere. Anybody else know?
Old 03-02-2015, 03:22 PM
timd38
timd38's Avatar
You could make one. Make it out of three pieces of cardboard then get a sheet of plastic and cut it out an the using a heat gun bend the 90 degree corners.
Old 03-02-2015, 03:45 PM
dentalfloss
Yes you can as I already made one but the OP was looking for one from a manufacture.
https://www.corvetteforum.com/forums...ir-intake.html
Old 03-02-2015, 05:42 PM
Dano523
Dano523's Avatar
Again, what do you need a heat shield for????
The intake is drawing air in from the front of the car, not the void, and the MAF is back at the TB, and would not be under the cover.
If you just want to have the void covered, then a sheet of ABS plastic, and a heat gun will allow you to produce a void cover instead. It not going to do anything for your set up, and in fact just be a Major PITA when you need to pull the filter to clean it, since it one more piece that has to be unbolted as well.
You can do a quick mock up with a sheet of cardboard, then transfer that to the ABS plastic sheet for the needed cuts and bends to produce a Void cover.
Old 03-02-2015, 06:09 PM
dentalfloss
If you have a stock filter, how is air coming in from the front of the car? There is no opening in that void. Take your filter out and look down there. Guy's are making openings and then trying to isolate any engine bay heat from the intake filter. Not everybody agrees on this theory but thats ok.
To Heat shields
Quick Reply: Heat shields
