1.460ft finally 10s on a grandsport
Yesterday finally I broke into the 10s on my 2011 grAndsport A6 Mods Cai/cam/conv/HDR
469hp with 1.4 60ft
469hp with 1.4 60ft
Received 2,061 Likes
Congrats for breaking the 11.000 barrier.
If you scanned your runs, take them to your tuner with the timeslips and have him tweak the tune for the high end. That'll get you in the 10.8's or 10.7's. A little more pressure in the tires, if you can still hook, will help too. Take him a copy of my slip, so the comparison of a lower HP car is easy to see. Your 1.48 60' and 10.94 ET and mine are nearly identical at those points, but inbetween, you pull away until halftrack and then I catch you at the stripe. Since I'm a lower HP bolton, your cammed car should continue to pull away. The aero drag difference is not that great at those speeds, but the tune appears to be holding you back a bit.
As soon as this ice melts...I am going to hit the track and hopefully start getting some seat time... You guys are killing me...but please keep it up
Congrats for breaking the 11.000 barrier. If you scanned your runs, take them to your tuner with the timeslips and have him tweak the tune for the high end. That'll get you in the 10.8's or 10.7's. A little more pressure in the tires, if you can still hook, will help too. Take him a copy of my slip, so the comparison of a lower HP car is easy to see. Your 1.48 60' and 10.94 ET and mine are nearly identical at those points, but inbetween, you pull away until halftrack and then I catch you at the stripe. Since I'm a lower HP bolton, your cammed car should continue to pull away. The aero drag difference is not that great at those speeds, but the tune appears to be holding you back a bit.
definitely something wrong maybe shift points
this is my mph with bolt/ons only
10.626 @ 126.98 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, hdr, ptb, tune, & more, DR - (3944) and look at the mph with this bolt on
10.788 @ 127.29 - LS1LT1 - 06 A6 - CAI, conv, fast, hdr, ptb, skinnies, tune, & more, DR - (5611)
and that was with 1.5 60 fts
