noise prob
noise prob
There is a clicking noise coming from the rear when i hit a bumb sometimes a slight bump. The car is lowered on stock bolts, i was thinking it is th he struts but i hear the bolts can make noise too
Sway bar end links will make a clunking noise. I could actually grab mine and duplicate the noise I was hearing if I twisted the end link quickly so I knew it was my problem. Easy to replace. I did all four in about 90 minutes. It is a fairly common wear item. Worth looking at them as it is an easy repair.
