Billet Alternators with new pricing
#44
Supporting Vendor
BLOWNBLUEZ06@RKT Performance (03-02-2016)
#46
Supporting Vendor
PM headed your way.
Thanks!
Thanks!
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
#47
8th Gear
Is this still avail in black for quick shipping?
The Billet Alternator design for 2015 has not changed, but the pricing has. Still using the 6-phase stator, 12-pole rotor design.
This alternator is compact and powerful! This case design even fits aftermarket heads with elevated valve cover rails using Katech valve covers. Many Corvette Forum members are running this alternator and some have reported that some, if not all of their troublesome electrical gremlins have been eliminated due to overcoming the voltage deficiencies that plague the Corvettes. Low voltage issues in summer stop-and-go traffic? Gone with this upgrade. Stock alternators heat up and are unable to even produce anything close to their rated output. This design incorporates higher efficiency and better cooling to keep the alternator output voltage high, even in higher heat situations.
"So what is there to gain from using the Billet-Tech alternator over the factory original?"
Better system voltage. "So what does better system voltage gain me?"
Many of the electrical components in our cars will perform better with full voltage.
Our ignition coils, fuel injectors, fuel pumps, cooling fans, electric water pumps, headlights (and the list goes on) will all perform better with better system voltage.
Why go with a Billet-Tech alternator over others? Take a good look at the cases of the competitors and you will notice that none of them have the beefy, stronger ears that Billet-Tech provides on their cases. Instead, you'll find some skinny ears with pins pressed in. These are modified cases, designed for another vehicle, modified to fit our cars and not nearly as strong.
4 finish options offered: Machined, black anodized, polished and chrome. I am stocking the more popular black and polished 170 amp units. 240 amp units, machined and chrome units are special order. As long as they’re in stock, I ship ASAP, typically the next business day.
The 170amp units shipped:
Machined 489.00
Black 515.00
Polished 539.00
Chromed 589.00
Add 50.00 for the 240 amp option.
If you’re wanting a custom alternator and 14v battery with 16v charging, PM me for details.
C5 owners, PM me. I’ve got something for many of you as well.
Shipping within the continental US is included. Contact me for shipping outside the lower 48.
If your serpentine system is upgraded from the factory 6-rib to 8-rib, let me know because we'll need to make you a custom pulley for that at an additional cost.
If you have a "flip drive", "Secondary drive", "Direct drive" or any variant of it, you may need a shorter belt. The drives use a K060370
and K060365 or a Dayco 6PK915 or Goodyear 36" length belt are your shorter options.
Paypal to blownblueZ06@gmail.com
For credit card payments, send me a PM with your email address and I will forward you an invoice.
When sending your payment, please verify your shipping address, add a phone number for FedEx and please give me your car info. Year/model etc.
About the warranty:
All Billet-Tech alternators are backed by a 2 year performance guarantee against manufacturers defect, by the manufacturer. Please visit http://www.mechman.com for more details.
All sales final.
The left one is machined and the right is polished
Machined
Polished
Machined
Polished
Black Anodized
Machined 489.00
Black 515.00
Polished 539.00
Chromed 589.00
About the warranty:
All sales final.
Machined
Polished
Machined
Polished
Black Anodized
BLOWNBLUEZ06@RKT Performance (03-09-2016)
#49
Supporting Vendor
I ordered through the forum to Bret, BLOWNBLUEZ06@RKTPerformance, for my 2002 Z06 a Black Billet Tech alternator 170 amp with self-starting regulator and tune.
The well secured package arrived even before the schedule time...
It was installed following the provided instruction and instantly showed 14.7 v on the DIC on initial start.
I went on a long hour and half drive yesterday in the 90*F Florida weather.
The DIC never went under 14 volts driving normally AC, Innovate wide-band, Valentine One and radio on. (with OEM GM Valeo alternator it was 13.0 / 13.2)
At stop light, with everything electrical turned on the DIC never went under 13.7 volts. (with OEM GM Valeo alternator it was 12.7 / 12.9)
Coils and Injectors are acting a lot smoother and idle is now where it is supposed to be (engine tuned OLSD since ever).
Thank you for your business Bret, I will recommend your products and your customer service.
Christian
Christian
BLOWNBLUEZ06@RKT Performance (03-31-2016)
#53
Supporting Vendor
Christian
Christian
Christian and I worked to isolate the voltage drops in the vehicle and then eliminate them so that he could enjoy the full potential of this alternator.
Thanks for allowing me to help you with your beautiful C5 and trusting me enough to take the additional measures needed to get your voltage up.
Bret
miami993c297 (03-31-2016)
#56
Just got my black one, looks awesome, 14.7V at idle now I just wish the positive terminal wasn't so damn close to the bracket, but it's fine, the rubber boot protects it still.
#57
Picked mine up from Bret today. Looks AMAZING! Cant wait to see it installed. I didnt look but does it come with the belt or do i reuse the stock one?
Thanks again Brett!
Polished bolts
Poolished 240 amp-1
Poolished 240 amp-2
Poolished 240 amp-3
Thanks again Brett!
Polished bolts
Poolished 240 amp-1
Poolished 240 amp-2
Poolished 240 amp-3
#58
#59
#60
Supporting Vendor
Reuse the stock belt in this case.
starchedup (05-13-2016)
